What does IDI mean?
Old Oct 22, 2012 | 07:03 PM
BeerCan500's Avatar
BeerCan500
Guys...Our idi burn about 75% efficient...di's about 68% efficient...yes it is the compression ratios...Now if you set up a simple propane injection on a 6.9 idi you will get closer to 88 to 90 percent efficiency... Imagine one with turbo also...you got a truck that will rival a 7.3 di with turbo...
Old Oct 22, 2012 | 09:56 PM
therifleman556's Avatar
therifleman556
Originally Posted by BeerCan500
Guys...Our idi burn about 75% efficient...di's about 68% efficient...yes it is the compression ratios...Now if you set up a simple propane injection on a 6.9 idi you will get closer to 88 to 90 percent efficiency... ...
Where is this number coming from? And efficient in terms of what?
When you consider brake thermal effiency even modern diesels are lucky to hit 40% meaning of all the energy produced from combustion, only 40%(at best) is transmitted to the wheels. Cooling alone accounts for almost 30% and the other 30% is lost to exhaust (these are rough figures and vary by application). There's an awful long ways to go before we even come close to the 73% thermal efficency 'ole Rudolph envisioned.
Old Oct 23, 2012 | 08:21 AM
hookedondiesel's Avatar
hookedondiesel
Originally Posted by Carly Phillips
Johnboggs21, what does E40D mean?
Although one of my trucks has one,...
Usually, it means trouble...lol
Old Oct 23, 2012 | 09:09 AM
RA31925's Avatar
RA31925
Ok ... but how many miles do you get per gallon of propane? Propane might make it run more efficiently, but propane's not cheap (over $2/gallon where I live).
What does your per-mile cost work out to be on a hybrid diesel/propane system? Less than a strictly diesel system? If not, then I'd say "efficiency" is irrelevant.
Old Oct 23, 2012 | 09:29 AM
sootman73's Avatar
sootman73
HAHA this is unfortunately true most of the time...
Old Nov 15, 2012 | 01:50 AM
86pullerf350's Avatar
86pullerf350
How does propane work in a diesel engine?
Old Nov 15, 2012 | 04:59 AM
fellro86's Avatar
fellro86
Pretty much the same as diesel, just in gaseous form. Propane is more of a power adder to the diesel, not so much stand alone. Compressed Natural Gas is actually a potential full replacement for diesel.
Old Jul 29, 2015 | 02:14 PM
Baizekyle92's Avatar
Baizekyle92
Originally Posted by johnboggs21
IDI means easy to work on reliable engine that makes good power.
it means it's a 10 minute job when an injector goes out haha
Old Jul 29, 2015 | 02:26 PM
85F350IDI's Avatar
85F350IDI
Originally Posted by 6.9 diesel nut
The ZF5 is the most common swap in IDIs. The replacement for the ZF5 was the ZF6. (5 speed with overdrive) Rarely swapped into an IDI, the ZF6 was used on the Super duty pickups until 2008.
So I must derail a wee bit and ask why the zf6 swap is rarely done, is it cause its too complicated or no need for a 6th gear?
Old Jul 29, 2015 | 02:58 PM
typefour's Avatar
typefour
If the zf6 was a double overdrive it would be swapped more, IIRC it is basically a ZF5 with a granny gear.
Old Jul 29, 2015 | 03:00 PM
85F350IDI's Avatar
85F350IDI
I thought the ZF5 already had a granny gear or am I thinking of the uh t-19
Old Jul 29, 2015 | 04:03 PM
Chevy_Eater's Avatar
Chevy_Eater
Neither, the T18 and NP435 are granny lows, ZF and T19 have a 'normal' range synchronized first gear.
Old Jul 29, 2015 | 05:13 PM
  #28
85F350IDI's Avatar
85F350IDI
What exactly is a double overdrive? Two over drive gears?
Old Jul 30, 2015 | 12:40 AM
  #29
Macrobb's Avatar
Macrobb
Yup.
So, with the ZF-5, you have a .76 overdrive ratio. So for each .76 rotations of the input shaft, you get 1 rotation of the output shaft.
The problem is that the zf-6 has the same overdrive ratio, so there's no benefit to upgrading -- all it does is shift 2nd lower, shift 3rd lower and add a new 3rd. So instead of 2 gears down low you get three.
To get highway use out of it(which is usually the reason for a transmission swap), you need to change your rear end gearing to 'shift' all the gears higher in the range -- going from a 4.10 to a 3.55 for instance.
At that point, you might as well just slap a Gearvendors Overdrive unit behind your ZF-5 and call it a day: https://www.gearvendors.com/fdrive.html - You can then keep your 4:10 rear end gearing, which is great for towing and torque, and have a highway gear that lets you cruise 60MPH at 1600 RPM... Good for your fuel economy and makes 70MPH cruising smooth and fun instead of a screaming motor.
Old Jul 30, 2015 | 10:00 PM
  #30
PlumCrazy7's Avatar
PlumCrazy7
Some folks might find it interesting that the new Kubota mini excavators have idi 4 cylinders. Our good heads help the idi motors get good mileage, they flow better than 6.0 4 valve heads. The ZF6 also has a different speed sensor output and mounting that make it a pain, couple that with the reasons others posted and you might as well find a wide ratio ZF5 that bolts up.
