2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Keyless Entry Code
Old Jul 4, 2016 | 05:47 PM
  #61
Texpedition's Avatar
Texpedition
This still works. I have had an 09 expedition for years and never knew the code. Saw this page.
Never could get the fuse box off, though. So I just jammed my iPhone in the space above it and took a dozen or so pictures from the top into the space. One of them was clear enough to make out the code.
thanks.
Old Sep 25, 2016 | 04:48 PM
  #62
Kris Hecht's Avatar
Kris Hecht
Thanks, viper! I recently bought a 2010 EB from a stealership that's pretty far from my house. They said the guy that could reset it "wasn't there that day." I called my local Ford dealer and they wanted $140 to reset/retrieve it. I checked this and the code works perfectly!
Old Oct 5, 2016 | 07:35 PM
  #63
Blueswede's Avatar
Blueswede
Trailering
Will this work on a 2011 F-350? My dealer wants $125 to retrieve the code.
Old Oct 5, 2016 | 07:43 PM
  #64
alwaysfords41's Avatar
alwaysfords41
Probably worth the 15 minutes to try it.
Old Jan 29, 2017 | 08:27 AM
  #65
Don Expedition's Avatar
Don Expedition
Flashing Security/Anti-theft light
Question,
Security light is flashing when engine is off and key is out, is this normal on a 2007 expedition? just started doing this. When engine is running no lights are on and no issues with vehicle, the light just flashes and won't go off. Please reply Thank you
Old Jan 29, 2017 | 10:49 AM
  #66
alwaysfords41
It is normal
Old Jan 29, 2017 | 11:34 AM
  #67
Don Expedition
Awesome Thank you, I put a new battery in a few days ago and just noticed the flashing light and it made me think the battery go dead over time if it was constantly flashing. Thanks again
Old Feb 5, 2017 | 10:35 PM
  #68
breastroker's Avatar
breastroker
This just worked on my 2008 Navigator Ultimate.
Old Mar 4, 2017 | 09:39 PM
  #69
Tinc's Avatar
Tinc
Have a 2013 and excited to look and save $60. Tinc
Old May 10, 2017 | 04:44 PM
  #70
clmyron's Avatar
clmyron
Had to register just to say THANKS! I bought a 2003 Expedition with no info on it. Saved me an expensive trip to the dealer! Code was on the same label!
Old May 10, 2017 | 05:54 PM
  #71
ericwudi0830's Avatar
ericwudi0830
That's awesome dude! any trip to the dealer saved is always good
Old Nov 4, 2017 | 11:11 PM
  #72
Woofiedog's Avatar
Woofiedog
Works fo 2014 Expedition
Thanks for the tip! On my 2014 Expedition I took off the top boldt holding the fuse box but could not get the bottom one off with the tools I have and the location. Ended up using an extendable dental type mirror and my iPhone to take a picture. Worked like a charm!
Cheers,
Marc
Old Feb 27, 2018 | 07:53 PM
  #73
Kevin Osborn's Avatar
Kevin Osborn
Factor door code
Where can I get factory door code for a 2006 expedition
Old Oct 21, 2018 | 11:23 PM
  #74
2000Ford2000's Avatar
2000Ford2000
Thanks
Found this thread and got the code from the fuse block and reset my personal code.
Old Oct 1, 2019 | 08:11 PM
  #75
Chris Hersman's Avatar
Chris Hersman
You’ve saved a lot of people a lot of money, thank you!!
Not many posts still carry weight 10 years on. Worked like a charm, thank you!!
REPORANGER
1983 - 2012 Ranger & B-Series
Sep 19, 2019 08:28 AM
bkuuz1
6.7L Power Stroke Diesel
Mar 14, 2016 02:33 PM
command37
Feb 22, 2016 08:35 PM
jimbomitch
Feb 16, 2016 08:08 PM
BradSmith-7.3L
Feb 16, 2016 07:12 PM
