Offroad & 4x4
Hook for the receiver hitch
Old Aug 14, 2009 | 08:40 AM
Team Danger's Avatar
Team Danger
I use a 6" strap with screw type clevises for recovery, i would take a few pictures of my towpoints but my truck isnt home right now. My strap was bought from www.thestrapguy.com and he is really good about fixing a strap for you if its starting to fray. Just like 75f350 said I used to use a 3" strap and it held up for 2 years then the truck got bigger and the strap only lasted about 4 more pulls.
Old Aug 14, 2009 | 01:40 PM
79f150toy's Avatar
79f150toy
Originally Posted by GregsSD
If you are using a 2" wide towstrap, you can slide the eye into the reciever and secure it with your hitch pin.
While I have done it in a pinch, I would not recommend using a TOW strap for vehicle recovery. There is a difference, since tow straps are generally rigid and tend to snap when you exert a large force upon it.....tow straps/ropes should be used for towing and recovery straps should be for recovering stuck vehicles...its a safety thing...the best recovery straps are similar to huge rubber/elastic bands that stretch, making snatching a stuck vehicle easier and less dangerous...just my 2cents tho....
Old Aug 14, 2009 | 02:17 PM
GregsSD's Avatar
GregsSD
I should have specified that I use a 2" recovery strap, not a rigid strap
Old Aug 14, 2009 | 02:39 PM
79f150toy's Avatar
79f150toy
10-4....while im sure most people on here know the difference, there may be some that do not....just want everyone to be advised.....
Mawk's Avatar
Mawk
Using just the hitch pin is pretty debatable in itself.
I have no opinion except to the fact that unless it's a straight pull, you'll fray the recovery strap on the edges of the hitch receiver.
In a bind I'll do so, but with their strap. But if I can loop it over the hitch tubing (without damaging the bumper cover when applying upward force) then I'd go that route instead.
It's always a gamble when you're using something the way it's not intended.
Old Aug 14, 2009 | 02:51 PM
hav24wheel's Avatar
hav24wheel
I have seen people do this before, and it required a hammer to get the pin back out because it bent, alot..
I also use 6 inch wide recovery staps.. i have a pintle hook in the rear, and a homemade insert in the front. i have been known to get alittle crazy pullin people out..
i have had to take 20 foot runs at the end of 50 ft of strap.. but thats when i was pullin out this rig in a different situation.
Ended up pullin the bronco out first, than the 2.5 ton backwards.
Old Aug 14, 2009 | 07:42 PM
351slug's Avatar
351slug
I got my Closed D hook up today, the receiver is a solid pc. The pintle was more than I could spend at the time. I am ready to go, I think wife and kids are going for there first mud bog. I hope she enjoys it
Old Aug 24, 2009 | 08:04 PM
torch4801's Avatar
torch4801
Was watching ice road truckers. A truck was in the ditch... fully loaded over 100k lbs up to the top of the frame in snow and this big ol loader jerked him out with a yellow strap. it wouldn't budge but the gave it some slack and gunned it a few times hard enough to make that rig jump when the strap was done stretching and shortened itself back up.
I've never used one before but now I'm a believer.
5851a
All Things Towing
Apr 25, 2016 07:32 AM
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
Apr 8, 2016 07:34 AM
RubberDuck
17
Nov 12, 2013 06:13 PM
