Mirrors
Old Aug 12, 2009 | 12:36 AM
97 HD's Avatar
97 HD
Mirrors
I wonder if the mirrors from an '09 will fit the '04-'08. Either the standard mirrors with the turn signals on the backs or the optional extendable tow mirrors.
Old Aug 12, 2009 | 01:50 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
any mirror from any truck from 2004-2009 will fit
alot of people have already done the swap. it is a direct bolt-on mechanically with zero modification required
now the wiring is another story. but take your time and it will all work just fine
Old Aug 12, 2009 | 07:26 PM
K.O-T.O's Avatar
K.O-T.O
Thats good to know. I was going to install a yellow turn signal light in them. I would be alot cheaper. I'm sure the door wiring is the same with or without the signal.
Old Aug 12, 2009 | 09:30 PM
Still Smoking's Avatar
Still Smoking
I got a 04 and installed the tow mirrors from the 07-09 and you had to move two pins and cut a ground. Nothing to hard.
Old Aug 12, 2009 | 11:49 PM
97 HD's Avatar
97 HD
Thanks. I dont want the tow mirrors just the power, heated ones that have the turn signals on both sides and puddle lamps. Its nice to know they will fit. When I get around to actually doing the swap I check back and see what(if any) wiring has to be changed. I have power, heated mirrors now so I imagine the wiring wont be hard.
Old Aug 13, 2009 | 02:34 PM
Still Smoking
Ya I was just saying they should fit and you might have to move the number 8 pin to the number 9 spot and the number 9 to the number 8.
makthenif
May 31, 2011 04:04 PM
Marlinda
Feb 5, 2011 05:04 PM
SturgeonHunter
Dec 23, 2010 04:17 AM
remix01
Feb 19, 2010 01:26 PM
cade
2004 - 2008 F150
Jul 4, 2005 08:22 PM
