Quick E4OD question
Old Aug 11, 2009 | 11:46 AM
12ozd's Avatar
12ozd
Quick E4OD question
Neighbor has a 1992 f350 that needs a trans.
Currently has a 1yr.old ford rebuilt in it.(needs another)
Question; It now will only move in forward gears.
When shifted to reverse,truck will "stall out". Every time.
He's getting a warranty replacement,I'm just curious what in the trans would cause that.
Old Aug 11, 2009 | 11:59 AM
jk080's Avatar
jk080
Transmission Rebuilder
It could be just low on fluid or the filter has fell off in the pan. A low fluid condition can cause the converter to lock up an kill the engine.
A bad pump can do this too. A long time ago we had one come into the shop and the engine would die in reverse and it turned out to be a bad speed sensor, the sensor was reading a 100+ at all times. When the computer saw this and it was shifted into reverse it would shut off the fuel supply causing the engine to run out of fuel, weird problem that I have never seen since.
Old Aug 11, 2009 | 12:18 PM
12ozd's Avatar
12ozd
We pulled the pan the other night just for S&G.
All is well in the pan.(fluid,filter etc.)
It will shut off immediately when put in reverse.
(same as letting out clutch on a manual w/ brake applied)
Drives perfect in "drive".
Old Aug 15, 2009 | 09:27 AM
fatboyf150's Avatar
fatboyf150
with the truck in netural, can you push it backwards by hand? this is what happened to mine. my 95 e40d rebuild thread.
Old Aug 16, 2009 | 10:34 PM
benshere's Avatar
benshere
I would suggest that before you spend big bux, you check the wiring harness from the E4OD up to the Drivers side top of the inner fender apron. Since it was replaced, it could have gotten pinched somewhere and just now shorted out/broken.
Since the shifting is all eletronic, a pinched/broken wire either at the MLPS could be sending the wrong gear indication to the PCM or the PCM shifting signal may not be getting to the solenoid pack in the tranny and a solenoid may not be operating or releasing. A little while back, somebody on here had a pinched harness from a replacement, different symptom, but had to do with shifting etc.
Might do some checking, its cheep--- LOL
Old Aug 16, 2009 | 10:40 PM
benshere's Avatar
benshere
jaleus
Nov 18, 2022 12:01 AM
bcso290
Jun 5, 2017 01:05 PM
Big_Texxan
13
Dec 21, 2015 09:04 PM
hanzy75
May 17, 2015 03:46 PM
Kizer12
Apr 21, 2014 06:14 PM
