Door lock actuators
Old Aug 11, 2009 | 04:07 PM
Brother Les's Avatar
Brother Les
So, the passenger side does the same as the drivers side, using the drivers side button or the passenger side button? It would be strange that both sides would go out at the same time (actuators or buttons) or were the time frames different with your problem (one side working and then both sides not working).
Old Aug 11, 2009 | 04:54 PM
damons's Avatar
damons
Door Locks
Hi, I found it odd myself, course I don't have the history since I just purchased this truck last week. But neither side works with either side's button.
Old Aug 11, 2009 | 05:14 PM
damons's Avatar
damons
User CP
Can someone tell me why my threads keep disappearing from my User CP?
My options say to keep threads for a week. It hasn't been 2 days yet.
Thanks.
Old Aug 11, 2009 | 06:39 PM
Stewart_H's Avatar
Stewart_H
Do you see them when you click on the "view all subscribed threads" link?
Within the one week period, if no new posts have been made, then the threads won't show unless you click the aforementioned "view all" link.
Stewart
Old Aug 11, 2009 | 06:56 PM
spdmpo's Avatar
spdmpo
I thought the same thing, read here:
https://www.ford-trucks.com/forums/8...t-working.html
They can and will all go out at the same time. Get the set of 4 for $26 and you'll have working door locks in a half hour.
Old Aug 11, 2009 | 08:45 PM
SpringerPop's Avatar
SpringerPop
Where's the set for $26? That will be a very good deal, indeed, if they are direct replacements.
Pop
Old Aug 11, 2009 | 08:58 PM
spdmpo's Avatar
spdmpo
They aren't direct replacements, they are universal actuators and just clamp on to the lock rod. You don't even mess with the factory actuators, just leave them be.
http://www.ford-trucks-power-locks.c...50F250F350.asp
I should have taken pics when I did mine, but I was in a hurry. I think the guy has some instructions on line so you can get a better idea.
Old Aug 11, 2009 | 09:15 PM
SpringerPop
I used that kind a few years ago to add door locks to my wife's Honda Accord LXi coupe.
The four-doors came with electrics, the two-doors didn't. It was a hassle to always reach across, so I just added them with a switch in the center console from a Dodge Caravan (it matched the Honda interior).
The only downside that I can see to using that kind on our trucks is that it makes the manual locking and unlocking with the key a bit harder to turn since you have to push and pull the actuator's gear train assembly.
Pop
Old Aug 11, 2009 | 09:24 PM
spdmpo's Avatar
spdmpo
I didn't notice any difference in the force it took to lock or unlock manually after adding the universal actuators. They have hardly any resistance to move them.
Old Aug 13, 2009 | 09:29 AM
damons's Avatar
damons
Keith, I am interested in this, I looked at the link, did you get JUST the PDL? What exactly do you get? Do you some how wire into the exisiting door switch or does he give you new ones??
Old Aug 13, 2009 | 09:34 AM
spdmpo's Avatar
spdmpo
I just got the actuators since the relays and lock buttons were still working. The factory actuators are just 2 wires just like those replacements. Just cut the two wires going to the factory actuators and then splice the new wires into them. Test it first because if the wires are backwards they'll work opposite of lock and unlock. Sorry I don't have a visual reference for you.
Old Nov 20, 2009 | 09:03 PM
damons's Avatar
damons
Someone gave me a link to buy some aftermarket acuators, but the company wants to know if I have a 2 or 5 wire? How do I know without tearing apart first?
Smokeythebear
1997 - 2003 F150
51
Apr 13, 2021 06:00 AM
Silverdawg
Dec 7, 2010 04:22 PM
bones68
Jan 16, 2006 03:15 PM
ruffed grouse
1997 - 2003 F150
Jun 28, 2004 11:04 PM
asavage
Aerostar
Jun 4, 2004 08:11 PM
