improving mileage
Old Aug 12, 2009 | 10:44 AM
  #31
Jim Allen's Avatar
Jim Allen
Originally Posted by WEST AUSSIE 94 250
What revs will these engines sit on happily as a maximum. Mine is 7.3 factory turbo that is basiclly stock as far as i know. At 100km/h in o/d i am doing about 2000rpm. Not sure of tyre size or diff ratio. If I put it out of o/d to tow I can only do 80km/h. Can these engines handle prolonged running at 25-2800rpm for instance or is it ok to tow in o/d on flat country. I have found the auto starts to get warm on long trips towing in o/d.
They will run happily in the high 2000s, though sucking fuel like no tomorrow. I did a solo 6000 mile trip with mine (see signature) back in 2000 and ran 70 mph a good part of that way. The truck was mostly bought for towing 18K GCVW at a sedate 55-60 mph, but it has had many occasions for long trips at speed over the past 22+ years I've owned the truck. To answer your question directly, when I'm not in a hurry, I like to use 65 mph as "maximum gallop."
Old Aug 15, 2009 | 08:19 AM
  #32
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
110km/h is the highway limit around here, 100km/h if towing. David85 I dont really understand why I would go smaller tyres and higher revs? I can do around 100km/h while towing out of o/d with about 2800rpm and just wanted to be sure the engine will be ok with this.
Old Aug 15, 2009 | 01:41 PM
  #33
David85's Avatar
David85
The idea would be to increase axle RPM, but to still use overdrive. Higher RPMs in the transmission will result in slightly better cooling. Other option is to go to taller tires and lock overdrive out completely. Again, this would bump your RPMs up, but not as high as 2800 so you would save some fuel.
But again, it depends on what your transmission temperature really is. By the book, your setup is already ideal and I suspect an aftermarket cooler would be the real solution if your tranny is really overheating.
Old Aug 15, 2009 | 09:37 PM
  #34
WEST AUSSIE 94 250
I have coolers coming out my ears. In front of my radiator I have air con cooler, power steer cooler and 2 heavy duty trans coolers running in parallel. The auto was rebuilt after the po cooked it, the trans guy put the coolers in but the problem I think is the standard 5/16 lines. They are too small to be efficient. I am going to build 1/2 inch stainless tube lines and incorporate an inline trans filter as soon as I get time. The trans doesn't get hot when not towing and it has only reached 200-210 twice but when it does the o/d light flashes and when I get it checked the code says exessive converter slip. The lock up seems to work fine as I have tested that according to my manual. The two times it has got hot has been in summer towing a good sized load in o/d. As a result if the trans gets to 180-190 now I either back off or come out of o/d.
Old Aug 15, 2009 | 09:44 PM
  #35
WEST AUSSIE 94 250
Ok just to add some details, I belive my diff is 4:10 like dave said. My tyres are 265/75-r16 and the temp sender is in the sump bung of the auto. Dave how do I convert tyre size to on road speeds and what are the auto ratio's assuming the lock up allows for no converter loss.
Old Aug 15, 2009 | 09:48 PM
  #36
David85's Avatar
David85
210 is the upper limit of the safe range. That shouldn't cause problems unless something else is wrong. Are you sure your converter clutch isn't letting go? That is a known problem with the E4OD transmissions. The apply clutch piston develops cracks that relieve pressure and prevent enough force for proper holding power. The result is slip, and heat.
Bigger cooler lines are a good idea idea, but I think your problem may not be solved by that.
Old Aug 15, 2009 | 09:57 PM
  #37
WEST AUSSIE 94 250
This is what the guy did to the auto when he rebuit it.
Old Aug 15, 2009 | 10:07 PM
  #38
joe f350's Avatar
joe f350
u clound buy a new truck for that
Old Aug 15, 2009 | 10:12 PM
  #39
WEST AUSSIE 94 250
I didn't pay it was the po. It has done about 20,000km since then.
Old Aug 15, 2009 | 10:18 PM
  #40
David85's Avatar
David85
I do find it curious that the builder would install a billet converter with only one friction element in it. Generally most aftermarket converters have 2 frictions even if they aren't billet.
There should have been an inline filter installed on the return side of the cooler at the time of the rebuild. This is actually required under ford warranties but not everyone else does. The idea is to prevent any shrapnel from the old transmission from getting knocked loose and killing the new one. Do you know if the factory cooler is still connected or if such a filter was installed? Sometimes they can become partially restricted. I am actually running my transmission on two series connected auxiliary coolers with the radiator cooler bypassed completely.
210 is still ok, but not ideal and you don't want to be spending all day there. Since the temperature is being measured at the pan, the internal temps are at least 10F hotter. If you have that much cooling in there, it shouldn't be running that hot. I am glad to see that the center support bearing has been upgraded though. Thats worth it's weight in gold.
Did the code scan reveal any sensor malfunction?
Old Aug 15, 2009 | 10:45 PM
  #41
WEST AUSSIE 94 250
Cooler in rad is totally bypassed. No filter that I have been able to find. No other codes when it got hot. I have had other trouble with trans before. When I got the truck the cruise control did not work. I messed around trying to test it and eventually swapped the unit out. It worked for about two days and then it stopped working and the trans started shifting strange, Snatching gears and changing up and down irregularly. I took it to the shop and it said the vss out of range code was up. They tested the vss and it was ok. Next I took it to an auto sparky and he looked at it for about three days. Finally it turned out if you disconected the cruise control unit from the connector and left it unplugged it was ok, just no cruise control. I have left it like that and had no further problems with the auto and can live without cruise control.
Old Aug 15, 2009 | 11:22 PM
  #42
David85's Avatar
David85
The VSS also drives your speedometer, cruise control and your rear axle ABS. If that was a problem, I can understand the transmission and cruise going out of wack at the same time, but I never heard of the cruise causing the PCM to get confused except on my truck (but I run an aftermarket controller).
There is a "range sensor" on the - um in your case its on the passenger side of the transmission on the shift lever. That is called the "manual lever position sensor, or MPLS sensor usually. That can also cause strange problems and it can be tested with an olm-meter and also has to be aligned properly to work. There is no adjustment for the VSS. Either it works or it doesn't.
Does your speedometer read perfectly steady? that can be a sign if a fault in the VSS somewhere (sensor, connector or related wiring).
Old Aug 17, 2009 | 04:35 AM
  #43
WEST AUSSIE 94 250
Vss good, no problem with speedo,mpls seems ok as well. As I said the auto only plays up when you plug in the cruise control. Not really phased though as if and when I get to it I will put in aftermarket cruise. Will do upsized trans cooler lines and then see how that goes this summer. Need to find out how to convert tyre sizes to road speed and will look at changing tyre sizes from there.
Sirpontiac
May 7, 2007 12:30 AM
blown5.0
Computer Chips & Tuners
Dec 9, 2003 08:01 AM
bainbob
17
Dec 31, 2002 07:07 PM
buckmeister2
Jun 24, 2002 06:18 PM
vortech347
1997 - 2003 F150
Apr 14, 2000 05:31 AM
