Mileage improvements.
Old Oct 7, 2002 | 07:42 AM
bainbob's Avatar
bainbob
Post Mileage improvements.
Old Dec 22, 2002 | 07:00 PM
Rogue427's Avatar
Rogue427
Bought my first diesel 3 months ago. I have a 97 F250 4x4 crewcab. I want to increse my fuel mileage. Looking for ideas. Has 83,000 miles and I do some towing. Thanks for any help.
Old Dec 22, 2002 | 09:17 PM
Ghostrider304's Avatar
Ghostrider304
I'd be willing to bet that a K&N type of filter and a larger exhaust would give you a couple of mile per gallon. It helped me by 2+ mpg.
And if you have'nt done so already chang the fuel filter.
Just my .02!
Will- :-X12
Old Dec 23, 2002 | 04:11 AM
Quadzilla's Avatar
Quadzilla
I agree with Ghostrider304. Start by putting in a clean fuel filter, and then open up the intake and exhaust. My personal choice instead of a K&N is a TYMAR intake, but either is a vast improvement over stock. Replacing the downpipe would be my first step in opening the exhaust.
Quadzilla
'95 F-350XLT Crew Cab SRW 4X4 PSD, 35X12.50X16.5's, Limited slip 4.10's, Hypermax downpipe, gutted EBPV, "Catless" in Seattle, "Renegade" 4" exhaust system, CTFD sticker, Air bags on all four corners, TYMAR intake, shimmed fpr, Diablo Delta chip, Fumoto valve, Autometer pyrometer, Sonnax valve, Tricumulator springs, Tru-Cool, HX mod, Magnefine tranny filter,
4R100 pan, Red Line synthetic in transfer case and both diffs, reverse shackle kit, big 'ol grin on driver's face.
And a wish list that gets longer every day.
(Thank God for a wife that likes big trucks.)
Pictures: http://community.webshots.com/user/quadzilla100
Old Dec 23, 2002 | 06:23 AM
vettehauler's Avatar
vettehauler
and once you get a better breathing machine, its time to consider a chip.
I have the SCMT that you see the webmaster hawking in the first post here in the diesel forum. I was sceptical that you could see such horsepower improvements, and still have an increase in fuel economy.
I have only had it for 3 tanks of diesel, but it appears I am getting about 3 mpg better than I was. Of course the major problem is that all that extra Horsepower has me putting my foot into it all the time.
Good luck.
Old Dec 23, 2002 | 08:27 AM
JoeBoost's Avatar
JoeBoost
As far as MPG increase , I have always heard :
1.Higher flow Airfilter setup
2.Larger downpipe and exhaust
3.Some type of tuning
4.Keeping the RPM's under 2000 when possibile
5.Keeping the speed under 65 mph
All above will help the MPG of any PSD truck
Old Dec 23, 2002 | 08:54 AM
f_pumillo's Avatar
f_pumillo
Agree with all. About the only thing Joe Boost missed was adding guages, especially if you are 1) adding a chip or SCMT and 2) towing.
I got the SCMT and guages are next. Then I attack the exhaust. Just with SCMT and keeping the tach below 2K, I went from 16.5 to 18.1 MPG. I have a K&N for now will replace that with Tymar or equivalent.
Old Dec 23, 2002 | 04:14 PM
Rogue427's Avatar
Rogue427
Where do I find a TYMER? Thaanks.
Old Dec 24, 2002 | 06:32 AM
vettehauler
Actually, I found that my mileage increased by 1.5 mpg if I do 73 MPH, (vs65 MPH) after I put the SCMT in. That has been the most amazing discovery to me.
Drew
Old Dec 24, 2002 | 08:01 AM
JoeBoost's Avatar
JoeBoost
Ya , I forgot to mention the gauges.
I currently have a two-gauge pillar with a boost and volt gauge.
Why a volt gauge you may ask ?? I guess it is the racecar guy thing in me always wondering what the voltage is of the vechile I am in...Girlfriend bought me a E.G.T gauge and stearing coloum pod mount for xmas which i need to install soon...
Old Dec 24, 2002 | 10:23 PM
HoseDog's Avatar
HoseDog
2000 RPM is a boring 55mph in my truck. Guess I should invest in an overdrive!
HoseDog
'95 F-250 PSD 4x4, Reg cab, Long box, K-N filter, 5-sp w/ limited slip 4.10's & 255-85x16's
Old Dec 25, 2002 | 01:14 PM
13MWZ's Avatar
13MWZ
>HoseDog
Or larger tires With my 4.10's and 35" tires 2000 rpm is right around 62 or 63 mph
Old Dec 25, 2002 | 02:52 PM
Quadzilla's Avatar
Quadzilla
[updated:LAST EDITED ON 25-Dec-02 AT 03:55 PM (EST)]Rogue427-
[url]TYMARPerformance(No Email Addresses In Posts!)[url]. That'll put you in touch with the guy that'll hook you up on a TYMAR.
Quadzilla
Pictures:http://community.webshots.com/user/quadzilla100
Old Dec 25, 2002 | 06:11 PM
goke1's Avatar
goke1
I have had 2 V10 and a Duramx and now have a power stroke. I have installed a KN filter and a performace devise to the oil pressure sensor which is for the injection system. Ford does have a hidden code will be put in the engine controller so you have to be carful what you put on it. If you truck is in warrenty and this code is it the ECM the warrenty is void . I used a Diesel Dynamic box which will add 50hp and is not seen by the ECM. I have gotten better fuel economy under load and empty. Empty I have gotten up to 23 mpg loaded will vary but 14 will get you in the ball park I pull a 29 FT travel trailer. My 250 is a 2002 built after Jan 1 4x4 crewcab. B You can have your cake and eat it. The Duramax is quicker out of the hole then the ford and quieter, thats the end of the story.
Old Dec 31, 2002 | 02:43 PM
chspyder's Avatar
chspyder
What mileage are you all getting? I am getting about 14mpg.
