remove dents from my grille shell?
Old Aug 10, 2009 | 12:25 AM
73shortbed557SCJ's Avatar
73shortbed557SCJ
Hello all i am brand new here and i just have a question
I jsut picked up a near mint 73-77 grille shell (cant afford the 200 bucks for a new one!) and the only thing wrong is there are two dents one on each side(the smooth flat sides) and i was jsut wondering if these would come out?(they seemed like they should easily enough?) I figured they would so i took her home and i tried to just push them out with my thumb but i hink its gonna take a bit more than that it seems?
Do you think they would come out and if they do (i hope!) what tools should i use not to damage the aluminum?
thanks and please help out this new guy!
Old Aug 10, 2009 | 10:09 AM
superd02's Avatar
superd02
wood, plastic and hard rubber hammers work well with aluminum
i have always tryed to get dents out of original shells rather than buy the cheap chinese crap
Old Aug 11, 2009 | 11:26 AM
bulletsneverlie's Avatar
bulletsneverlie
Yep, use a hard non-metal hammer, and make sure the pounding areas are nice and clean and flat, or that they match the desired contour. Lay the other side on wood as you hammer. When you hammer, start hammering softly at first, then increase pressure as needed, checking the dent after each blow, until the dent is out. Try to make nice dead blows (minimal hammer rebound). Aluminum is soft, so be careful.
I banged a couple of dents out my grill, but one mangled corner had to be mended with JB Weld, sanded, and I've painted the whole grill with silver high performance rim paint. Actually looks pretty good.
Friesian-Bronco
18
Mar 24, 2025 10:57 AM
mrpotatohead
Nov 18, 2016 10:43 AM
Ressinoff
Nov 14, 2016 04:34 PM
Aaron-71
45
May 24, 2012 08:46 PM
JHag04FX4
2004 - 2008 F150
Jun 9, 2006 03:00 AM
