Strange AC problem & its 95 outside HELP!
Old Aug 9, 2009 | 02:15 PM
okiepc1's Avatar
okiepc1
AC works just fine at idle, cold and blowing good, problem is going down the highway under power, no cold air, but if you coast, plenty of cold air. It acts as if something closes off under power and reopens when coasting.
Gauges check out, 38 low, 280 hi what could the problem be? I cannot find a vacuum leak.
Thanks for any help
okiepc1
85 F150 302 AT Explorer
Old Aug 9, 2009 | 02:37 PM
ctubutis's Avatar
ctubutis
Sounds to me like a lack of a fruit juice can or other vacuum reservoir (some trucks use
softball-sized black, plastic ***** for the HVAC vacuum), these are the things that
retain/store vacuum during times of little to no vacuum supplied by the engine, e.g. during
heavy acceleration. Or, perhaps a vacuum leak affecting the vacuum motor that operates
the HVAC system.
Old Aug 9, 2009 | 04:36 PM
okiepc1's Avatar
okiepc1
You verified my suspicions. my pickup has both, the fruit can and the ball so it looked like the black plastic ball ran the show for the ac. I had an extra reservoir from some other application, hooked it up & nice cold air uphill or down.
, problem solved
Thanks for your input
okiepc1
Old Aug 15, 2009 | 02:09 PM
Cnorth6525's Avatar
Cnorth6525
check your vacum hoses on the firewall closest to the blower motor. Cap the middle one and the left one goes to the blower motors, and the right one goes to the intake.
okiepc1
Oct 6, 2014 08:16 AM
okiepc1
17
Aug 4, 2012 01:45 AM
okiepc1
13
Sep 20, 2009 08:33 PM
okiepc1
21
Aug 1, 2009 03:55 PM
okiepc1
Jun 21, 2009 09:19 AM
