problems with ignition and going into gear
Old Aug 8, 2009 | 11:33 AM
rb21747's Avatar
rb21747
I have a 1986 ford f-150 ext cab truck - when I turned the key this morning- nothing happened so I cranked it from the cylanoid under the hood but it wont come out of park now - can't get it to go into gear and it still wont crank with the key - I bypassed the saftey and it still won't go into gear - anyone know what the problem is?
Old Aug 8, 2009 | 12:22 PM
fellro86's Avatar
fellro86
Is there the normal resistance to turn the key? It may be that the part in the column, the rack, broke inside and is not releasing the gear lock.
Old Aug 8, 2009 | 01:16 PM
rb21747's Avatar
rb21747
no resistance when the key is turned
sounds like your right - is the rack a part that can be replace or do you need to replace the entire column? If it can be replaced is it a dealer part?
Old Aug 8, 2009 | 02:32 PM
fellro86's Avatar
fellro86
You have to tear the column all apart to replace it. You can find replacement parts to do it though.
fordgirl2000
May 23, 2015 07:46 AM
Sands77
Nov 14, 2013 06:48 PM
95van
May 14, 2007 03:42 PM
alpine7572
1997 - 2003 F150
Oct 30, 2005 10:40 AM
