Sponsored by: Real Truck
4x4 problems
Old Nov 14, 2013 | 04:00 PM
Sands77's Avatar
Sands77
4x4 problems
My 2005 ford f250 fx4 won't activate when I turn the key the light illuminates then turns off but when I start the truck and select it it doesn't go into gear
Old Nov 14, 2013 | 06:30 PM
redford's Avatar
redford
FTE Leadership Emeritus
Based on the thread title I am assuming that you mean your truck will not go into 4 wheel drive.
That is what is supposed to happen, so that's a good thing.
You mean your truck does not go into 4H or 4L? Do you have a manual transfer case or an electrically operated transfer case? How have you determined that the truck is or is not in 4 wheel drive?
Old Nov 14, 2013 | 06:48 PM
Sands77's Avatar
Sands77
Originally Posted by redford
Based on the thread title I am assuming that you mean your truck will not go into 4 wheel drive. That is what is supposed to happen, so that's a good thing. You mean your truck does not go into 4H or 4L? Do you have a manual transfer case or an electrically operated transfer case? How have you determined that the truck is or is not in 4 wheel drive?
I have an electrical operated case. When I select it to 4h or 4l nothing happens to verify this I select 4h or 4l let someone drive an notice nothing is happening with the forward drive shaft it isn't moving.
IHpuller450
6.4L Power Stroke Diesel
Jun 16, 2015 08:56 AM
midsouth
18
May 8, 2014 05:50 PM
fellro86
Dec 31, 2012 08:05 PM
sansinga13
Mar 16, 2012 12:17 PM
Redneck80
Dec 20, 2003 06:43 PM
