Oil & Lubrication
oil cooler?
Old Aug 28, 2001 | 01:00 AM
77_f250_460's Avatar
77_f250_460
oil cooler?
i was wondering if anyone knows of a good oil cooler, and a relocation kit for my filter....i have a trans cooler built into the HD radiator but the truck didnt come with a oil cooler...when towing 5000 lbs the temp stayed at normal operating temp but i want the extra security...thanks
Old Aug 29, 2001 | 12:37 PM
georgedavila's Avatar
georgedavila
oil cooler?
You can find oil filter relocation kits in all the vendor catalogs. Be certain to use steel braided lines from the filter adaptor on the block to the remote filter mount.
I use the B&M stacked plate coolers for both transmission and oil coolers. That design acts as a bypass by using the oil viscosity when the oil is cold.
Old Aug 29, 2001 | 03:34 PM
beartracks's Avatar
beartracks
oil cooler?
I vote for the braid lines. I used the rubber (?) lines and they started to leak/harden after a year. I don't trust them with my oil. Also my oil cooler wouldn't fit in front of the radiator/A.C. so I built a bracker and mounted it horizonal under the radiator with a small sheet metal scoop. I also used a thermostat fitting for the winter.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Aug 29, 2001 | 06:02 PM
georgedavila
oil cooler?
I also fabricated brackets under the hood to mount my trans/engine oil coolers. One is on top of the other with about 1" between them. A 10" puller fan is mounted on the top (engine oil) cooler.
My experience with rubber oil lines was almost a disaster. At 60mph one of them came into contact with a header and created an instant hole in the line. I almost lost control of the rig from oil smoke on the header, but got the engine shut down before any internal damage occured.
Old Aug 29, 2001 | 09:44 PM
cubster's Avatar
cubster
oil cooler?
2006powerstroke90
Sep 7, 2014 11:33 AM
wisevoss
Jan 29, 2014 04:51 PM
duckymax
Nov 28, 2011 09:23 PM
vlietracer64
Nov 3, 2010 10:35 PM
