Need help identifying axles
Old Aug 6, 2009 | 09:50 AM
davelength's Avatar
davelength
This is a 1992 E350 SD with a Quigley 4x4 setup.
The front diff I believe is a Dana 44. It has "42513" on the housing and the tag says:
45-11
4.09
The rear diff, I do not have a guess. It has "853" on the top and 42853 towards the rear cover. The tag says:
4.09 FLUA PA
605487-10 LS
The door tag has the code "C5" which I believe is the 4.10 limited slip.
As you can see, the vehicle is stripped down for a major rebuild. I would like to figure out what components it has so I can get any needed parts, as well as identify any potentially weak components as I rebuild this for performance. The E4OD will get a complete performance rebuild, as will the 351. The transfer case is a Borg Warner 1356, which if I understand correctly, should be plenty durable.
Thanks!
Dave
Old Aug 7, 2009 | 10:23 PM
JerseyMudIsFun's Avatar
JerseyMudIsFun
http://npd.dirxion.com/WebProject.as...Code=fod09flx#
click to page 112 in online cat
Old Aug 8, 2009 | 11:13 AM
Mike1996F350's Avatar
Mike1996F350
The rear diff is a full float, and I would assume that they didn't change it out so it should be a Sterling 10.25, the front I would be more inclined to believe is a 60, since that's what went in the F-350s. Hard to tell from the picture though. You could measure the u-joints in the knuckle, if it's a 60 they should be about 4.40" from outside of cap to outside of cap, if its a 44 they will be about 3.30".
Old Aug 9, 2009 | 01:01 PM
davelength's Avatar
davelength
Ok, I found "44 BA526 8" stamped in the front axle tube, so that appears to be a Dana 44. On the front webbing of the rear diff I found "60-150" cast, so it looks like it is a Dana 60 for the rear.
Thanks!
Dave
davelength
43
Apr 15, 2010 06:53 PM
davelength
13
Dec 13, 2009 07:41 PM
davelength
Oct 12, 2009 07:08 PM
davelength
Sep 27, 2009 01:50 PM
davelength
24
Sep 17, 2009 07:39 PM
