Spark on throttle linkage
Old Aug 6, 2009 | 09:01 AM
bucks77ford's Avatar
bucks77ford
I noticed last night while messing with my truck that I have a constant small spark on my throttle linkage on my carb. BTW, it's a 77F250 with a quickfuel Ethanol carb with an electronic choke. That really probably don't make a difference anyway. Is this a common thing and do I need to run a grounding wire from the carb to the rest of the engine?
Old Aug 6, 2009 | 06:41 PM
LxMan1's Avatar
LxMan1
You shouldn't, it should ground thru the carb studs to the intake manifold. Perhaps you need to check your intake to cab chassis ground wire.
Old Aug 6, 2009 | 11:13 PM
fmc400's Avatar
fmc400
MSEE
I agree, you're missing a ground strap from the engine to the firewall.
77beater150
WTB - Parts & other
Apr 30, 2014 08:32 AM
buttruck
May 23, 2008 11:58 PM
tip49
Jul 17, 2007 01:22 PM
tapenick
Jan 3, 2004 12:14 PM
CodaSmog
Apr 21, 2003 03:19 PM
