Sponsored by: Real Truck
stock brake pads?
Old Aug 5, 2009 | 11:13 PM
Zinfinity's Avatar
Zinfinity
stock brake pads?
Does anyone advise on using stock brake pads for my 2005 F-350 PSD?
Ive always been a fan of using stock pads but there seems to be a lot of talk on here about after market brakes.
Old Aug 5, 2009 | 11:27 PM
ford7379trucks's Avatar
ford7379trucks
im not sure but i think i heard the stock pads and rotors were good for a really long time
Old Aug 6, 2009 | 04:59 AM
sandmanf250's Avatar
sandmanf250
carquest pads and stock rotors give good performance for the money.
Old Aug 6, 2009 | 06:59 AM
DetailerDave's Avatar
DetailerDave
A few years ago, when I first got the truck, I had an issue with warped rotors on the front. I took them to a Toyota dealer, where my step-son worked, and turned them myself on their machine, so I knew they would be done right. I put the best pads available from Pep Boys on, and they lasted a long time. I recently replaced them without turning the rotors, with the best pads from the local Federated auto parts, and no complaints there either. I wont hesitate to use stock stuff, again.
Old Aug 6, 2009 | 07:13 AM
12ozd's Avatar
12ozd
Nothing wrong w/ stock brakes.
Old Aug 6, 2009 | 08:19 AM
motown's Avatar
motown
Do a search on Hawk LTS,s. They are the most popular on this forum.
Old Aug 6, 2009 | 06:10 PM
david0505's Avatar
david0505
Hi,just replaced front hubs as preventative maint.,changed all brake pads with Motorcraft Superduty pads while in there,the original pads still had about 30% wear left...this is at 97,000 Mi. hard to beat that...Dave
Old Aug 6, 2009 | 09:25 PM
Frankenbiker's Avatar
Frankenbiker
99-'04 PSD's had brakes that some considered to be inadequate.
'05 and later trucks had MUCH bigger brakes (which is what necessitated the change to 17-inch wheels) and as such have not needed the aftermarket "beef-up" that the older trucks needed for adequate stopping power. Combined with the engine/tranny braking programmed into the '05+ tow/haul mode, the combination can bring even a heavily loaded truck to a stop post-haste.
Indeed, I can very nearly stand my '07 on it's nose. VERY nice.
-blaine
Old Aug 6, 2009 | 09:42 PM
big yeller's Avatar
big yeller
I just changed pads on my 06 F350 w/48,000 miles. I went to the Hawk LTS pads. What a big differance!!! The pads on the truck were the original ones (48000) with about 25% wear left. Rotor were fine, on need to have them turned. If they were warped, I would have gone with the Power Slot Cyro's Anyway, I'm sure stock pads are just fine. But the Hawks did make a noticeable differance in braking. I got them from AutoAnything.com fronts were $80.00 rears were $75.00 Good luck on your project, hope this helps, Howard.
Old Aug 6, 2009 | 09:45 PM
Zinfinity's Avatar
Zinfinity
Which Hawk LTS pads did you go with the "Superduty" or the regular?
Old Aug 7, 2009 | 12:17 PM
big yeller's Avatar
big yeller
Sorry for not getting back to you sooner. The ones I got were the LTS, not the HP super duty. I felt the HP was more for fleet use, where there was a daily max load on the truck.
I have a fifth wheel trailer, @ about 12,000 lbs and I wanted a better pad to help stop the thing. We get out about 6-8 times a year
I also felt, after reading Hawks web sight, the HP would be pretty hard on the rotors, so thats why I went with the LTS's. Hope this helps.
As a side note, I just checked Anything Auto and their prices went up;
fronts are $92.00 rears are 79.00
Howard
Old Aug 7, 2009 | 03:47 PM
motown's Avatar
motown
I just bought a set of hawk LTS's for my 05 F250, of front & rears from Street side Auto dot com for $135 & free shipping. I googled for a coupon code and got a great deal on my set.
Old Aug 8, 2009 | 04:05 PM
Haoleman's Avatar
Haoleman
Good info. My 02 Super duty diesel had rotor hot spots (pulsating) at 15,000 miles. Dealer turned the fronts on the truck. Said New Hampshire winters ( salt was the cause). Now at 60,000 the same thing is happening. I have serviced and greased the rub points and all is free ( no sticking calipers). Should I replace the rotors at this point and get some different pads? Which rotors and pads and where to buy? I don't currently tow anything but do plan another large fifth wheel in near future.
Thanks,
Terry
Old Aug 8, 2009 | 05:54 PM
RIF350guy's Avatar
RIF350guy
I hear carbon metallic pads are the way to go. I've yet to try them, but i've read about some who have. They say they never felt such good stopping power. I would like to try them, but don't know how they'll be on rotors.
The only trailer I pull with out trailer brakes is a two place clamshell sled trailer. Little under 2500 pounds loaded. It would be nice to have a little better stopping power, the two haul mode down shifts to hard at times and I feel like the tailer is going to go right around me.
I was thinking of trying the carbon metallics with some aftermarket slotted rotors when I do replace the stock ones.
Has anyone tried this type of brake pad?
Old Aug 8, 2009 | 06:05 PM
89stinger's Avatar
89stinger
I put Hawk HPS pads on my 03 F250 and I love them. Lots better that stock I think..
STEVEad1
Mar 28, 2014 02:40 PM
guitarpicr
May 2, 2010 02:54 PM
mjlevi
Jan 15, 2007 09:52 AM
mjlevi
Dec 18, 2006 01:36 PM
