Sponsored by: Kumho
ceramic brake pads?
Old Dec 15, 2006 | 07:35 PM
mjlevi's Avatar
mjlevi
ceramic brake pads?
Has anyone used ceramic brake pads on their Superduty? any pro's or con's to these type of pads for replacement?
Old Dec 16, 2006 | 11:58 AM
pops_91710's Avatar
pops_91710
https://www.ford-trucks.com/forums/3...rake-pads.html
Old Dec 16, 2006 | 05:18 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
PROS - Last longer... work cooler... less dust... less warpage... better performance
CONS - More expensive... can sometimes take a little bit longer to "seat"... in other words it may take 50-100 miles of driving to get "full" braking power out of them.
Really good stuff, those ceramic brake pads are!
Good luck
Old Dec 17, 2006 | 08:54 AM
pops_91710's Avatar
pops_91710
The 'con' about wearing out the rotors sooner is really offset considerably when you consider the longevity of the brake pad's lifetime. Several sets of organic or other softer materials cost as much as or more (labor is the same on all types) than rotors. So, my preference goes to the ceramics. Fewer change-outs, less dust build up, safer stopping, etc.
Old Dec 21, 2006 | 10:08 AM
50calmike's Avatar
50calmike
Had them on my 99 250 and the stopping power was greatly increased. I would recommend them.
Old Dec 21, 2006 | 11:54 AM
aurgathor's Avatar
aurgathor
I do my own brakes (and pads are very easy to change) and found that it's better to use softer pads so I don't need to worry about rotors -- more expensive and lot more work. But this is all IMHO.
Old Dec 22, 2006 | 07:23 AM
pops_91710's Avatar
pops_91710
My point was this: Eventually all rotors wear out regardless of the composition of the pads used. So, you will be doing it no matter what. But "more expensive" is a fallacy because you have already spent as much (or more) on pads as would have on rotors. Ergo my comment that you are not really saving any money.
Old Dec 22, 2006 | 08:41 AM
merlynr's Avatar
merlynr
I usually buy "lifetime guaranteed" pads and so most of the time they are free as long as you own the vehicle. I agree with pops_91710 because pads are getting easier to change as the technology improves. I have wanted to try the ceramic pads, but afraid they will wear out my rotors.
Old Dec 22, 2006 | 12:26 PM
pronstar's Avatar
pronstar
Originally Posted by MazdaRangerGuyInSTL
PROS ... better performance
I will agree with you that they can offer better performance than stock.
But I haven't seen any data showing superiority versus a non-ceramic performance pad.
This police-intereceptor test didn't show a performance advantage at all for the ceramic pads tested:
http://www.nlectc.org/pdffiles/Evalu...kePads2000.pdf
Old Dec 22, 2006 | 01:20 PM
aurgathor's Avatar
aurgathor
Well, my Bronco has 195k on it, and I believe it is still on its original rotors. Got it at 120k, so I can't be 100% sure, but it was a govt vehicle, and they sell them before major repairs from wearout kick in. Aside from turning them at 125k, 2 brake pads, and some brake fluids, nothing else were done or used since I got it. Last I checked the rotors were still in excellent shape. Not sure how long a rotor last with ceramic pads, but I consider mine pretty good, and I used only OEM or equivalent pads.
Old Dec 22, 2006 | 10:39 PM
pops_91710's Avatar
pops_91710
Everything is relative to how a vehicle is driven and environmental conditions. I don't see how what you have said has anything to do with my comment. You have to compare it to the same vehicle used under exactly the same conditions. Nothing said here invalidates my statements.
Old Jan 7, 2007 | 07:02 AM
Gevans17's Avatar
Gevans17
Ceramic Pads
Less brake dust as well, I believe
Old Jan 15, 2007 | 09:52 AM
Mr Incredible's Avatar
Mr Incredible
I put ceramic pads on my 98 Z28. The increased braking power was very evident and the brake dust is reduced by at least 80%.
How they would do for my truck, I don't know. But I can't imagine they would be a bad choice.
rshep
Apr 13, 2016 11:32 PM
F 250 6 liter
Oct 18, 2014 10:03 AM
mcassel1
2004 - 2008 F150
Aug 23, 2010 02:25 PM
babock
2004 - 2008 F150
19
Sep 19, 2006 04:25 PM
mdpnh
Jul 13, 2005 12:06 PM
