finding a receiver hitch
Old Aug 5, 2009 | 07:36 PM
brown 4x4's Avatar
brown 4x4
I'm having trouble finding the right receiver hitch for my 97 F-250. I've ordered two from Napa with no luck yet. The first one was supposedly "bolt on" but was much lighter (class 3) than I told them I wanted. The second one is a class 4 but looks like it will have issues clearing the bumper.
Is there a certain hitch I should be looking for? I want at least class 4, and I have a factory step (no drop) bumper. I also want to keep the spare tire underneath. Any recommendations on what to look for and where? I need to get something quickly...my F-150 is all I have now to tow with.
Old Aug 5, 2009 | 08:22 PM
Lanny Sutton's Avatar
Lanny Sutton
You'll have a tough time finding anything class 4 or heavier that will let you keep the spare undeneath. Go to www.reeseprod.com .
Lanny
Old Aug 5, 2009 | 08:30 PM
pjwoolw's Avatar
pjwoolw
Here is an option if you have the budget.
Old Aug 5, 2009 | 08:42 PM
helifixer's Avatar
helifixer
I didn't like anything factory made so I made my own, 1'2 inch plate down the sides of the frame 4 inch square tubing welded in between than a receiver welded to that, 3/8 gusset from tubing to receiver 3 3/4 inch grade 8 bolts on each side in sheer loading
Old Aug 6, 2009 | 01:29 AM
joe_13894's Avatar
joe_13894
helifixer... WOW!
1/2" plate, 3/4" bolts!
I have a 42" extension hitch I built myself and I used 3/8" plate and 5/8" grade 8 bolts. I thought I was doing overkill.
Old Aug 6, 2009 | 06:31 AM
Bobcat7's Avatar
Bobcat7
I had good luck, price-wise and quick-shipping-wise, with southwestwheel.com a div of trailerhitch.com . I got a 15k gtwr hitch for my superduty that was a great fit and cheaper than the trailer place around here and shipped to my door!
Old Aug 6, 2009 | 09:41 AM
Mat J's Avatar
Mat J
etrailer.com is a good cheap place to check out.
Old Aug 6, 2009 | 01:47 PM
mkeith54's Avatar
mkeith54
As much as it may scare you, check with a ford dealer, one out in the country. Mine cost no more than a class 3 from a trailer place. Even installed it was cheaper than running around trying to find one.
Old Aug 6, 2009 | 03:07 PM
MLCinNCTX's Avatar
MLCinNCTX
Find a U-Haul dealer that installs hitches. Mine is a Class 4, the spare clears, and less than $200 installed. It did require drilling by the installer. Since I bought it in 1996 the price may be a bit higher now.
Old Aug 6, 2009 | 11:01 PM
brown 4x4's Avatar
brown 4x4
Well tonight I installed the class 4 from Napa (Valley brand). I really need to haul a vehicle tomorrow and once I test fitted it, it looked like it would work. I'm much happier with it than I thought I would be. It did require drilling, but looks good and the spare clears. The only thing now is where to put my light plugin. I wanted a factory one in the factory spot, but it looks like that won't work with any receiver hitch.
Old Aug 7, 2009 | 07:20 AM
mkeith54's Avatar
mkeith54
Mine mounts next to the ball on the bottom of the step bumper, far as I know the original spot. That reminds me, I broke the cover door off the factory one and still need to R2 the part.
abyars111
Oct 17, 2012 01:47 PM
bryan_johnson
All Things Towing
Jul 6, 2004 08:08 AM
lindsayshuffreg
1966 - 1977 Early Broncos
Aug 7, 2003 10:22 PM
Pkupman82
Jul 22, 2003 05:35 AM
