Sponsored by: Auxito
EVAP fuel lines
Old Aug 5, 2009 | 01:45 PM
opnjim's Avatar
opnjim
Smile EVAP fuel lines
I have a 1997 F150. The evap fuel lines that run to the charcoal canister
need to be replaced because of rust. They run inside the rail on the drivers side and pickup the fuel vapors from the fuel tank. Can I use a fuel
resistant rubber hose? Since the evap lines are bigger in diameter I am concerned about using medal replacement because of the bend in the lines.
Thanks
Jim
Old Aug 5, 2009 | 09:09 PM
torkum's Avatar
torkum
You can try it but be aware if you get a EVAP code that is probably were its coming from. Make sure the connections are good.
KsCop
35
Aug 11, 2014 03:25 PM
swampthang
Jun 21, 2014 04:41 PM
Wbruiser2
Apr 16, 2013 10:48 AM
JB-1
71
Jun 23, 2012 09:32 PM
paredneck33
Oct 17, 2010 09:09 PM
