Rev limiter
Old Aug 5, 2009 | 09:44 AM
tommyleea's Avatar
tommyleea
Rev limiter
2001 Explorer Sport Trac with 4.0 motor. Drove to town and back yesterday with no problems. Then, I was just sitting in the driveway in park, and revved the engine up. It won't go past 3,000 RPM. Is this normal for this vehicle? Never mind. I did a search, and found out the computer limits the no load RPM. Thanks anyway. Great site.
TommyJ
Old Aug 7, 2009 | 06:30 AM
tommyleea's Avatar
tommyleea
Follow up to the rev limiter. If I am driving down the road, let up on the accelerator, and then push the accelerator again, there is a faint high pitched chirp (not the tires spinning). Could this be related to the rev limiter feature? I was playing around with it yesterday, and the chirp seems to appear around 3K. Anyone else familiar with this noise? It is faint, so if you have the radio on, you probably won't hear it. Thanks
TommyJ
Old Aug 7, 2009 | 10:57 AM
aquanaut20's Avatar
aquanaut20
Might be the belt loading up and slipping momentarily.
Old Aug 7, 2009 | 12:12 PM
shorod's Avatar
shorod
I'd suspect either the belt (as mentioned above), an idler/tensioner pulley, or possibly a dry u-joint.
You wouldn't consider it a "honk-like" sound would you? Some Fords have TSBs on "honking" sounds from the intake air tubing.
-Rod
Old Aug 9, 2009 | 07:54 AM
tommyleea's Avatar
tommyleea
-Rod
Not honking, just a chirp.
swirlparanoid
Dec 9, 2013 06:14 AM
VinnyT73
Aug 1, 2012 07:49 AM
dsirekis
Apr 23, 2010 07:55 PM
hoxiii
29
Apr 27, 2007 07:53 PM
the tank
Sep 18, 2004 12:28 AM
