Sponsored by: Auxito
Code PO300 any help?
Old Aug 3, 2009 | 05:46 PM
killercarpenter's Avatar
killercarpenter
Had a diagnotsic test and called for a code po300 any ideas what this is it said cylender misfire. Any particuler one?
Old Aug 3, 2009 | 06:04 PM
pintopower8's Avatar
pintopower8
Random multiple misfire, this means that basically all or many of the cylinders have misfired in a short amount of time. I take it you are experiencing a drivability problem...
Old Aug 3, 2009 | 06:08 PM
killercarpenter
drives fine just idles like crap. Under load it accelerates fine. I was thinking with 141,000 mi on her she could use some coils and new plugs.
Old Aug 3, 2009 | 06:13 PM
pintopower8
Well with all theory in mind, a bad ignition would fail under load not at idle. Sounds like you have a vaccum leak, egr coming on, bad MAF, etc.... The code you gave tells nothing. You need to know more.
Old Aug 3, 2009 | 11:58 PM
fordmerc's Avatar
fordmerc
I'd say with 141K miles and you just now thinking about a plug change, you have lots of issues with the truck, hidden or obvious. Change plugs, wires/cops and boots. Clean egr ports and maf. Ck pcv system for vacuum leaks. Clean throttle body and replace fuel filter.
Old Aug 4, 2009 | 07:57 PM
killercarpenter
Changed plugs a few years ago at about 75,000 mi. And havent had any major issues since. Regular oil changes and about 75 mi. round trip to work.
Old Aug 4, 2009 | 09:04 PM
pintopower8
try pinching the vaccum line to the egr.
Duncan Scott Millar
18
Aug 23, 2015 12:22 PM
VADER2004
Nov 21, 2014 01:05 PM
basecamp
EcoBoost (all engine sizes)
May 14, 2014 08:51 AM
hhf250
1997 - 2003 F150
Apr 1, 2014 06:41 PM
arkredneck
13
Dec 12, 2013 07:14 AM
