Hi guys...truck hard to start when cold(BELOW 28*) any help on the codes would help..
sorry guys..thought it would help to see code definition linked to codes ...HOPE THIS WORKS BETTER...THANKS GUYS..
Hi guys...truck hard to start when cold any help on the codes would help..
The P0611 means your FICM needs to be repaired, that is the one I would fix first. Go to www.FICMrepair.com and Ed will get you taken care of. The Cam and Crank codes can come from a lot of cranking attempting to start it. The Cylinder contribution codes may indicate those injectors need to be replaced.
No barley just cant see anymore. You and cheezit are right but untill my wife told me the codes I just could not see them.
Not that either of ya needed my confirmation at all. But I really like to see what is being said or shown before I reply to a post.
your alt,battery,cables or ground points could have issues causing charge problems that led to FICM Fail
address you FICM and any charge system issues before moving on to Contribe DTC's
OK....about 4 months ago my alt went on the way home...all electricals(gauges went south)..until I replaced alternator on side of road...had batteries check as soon as I replaced alt..both checked out great..
