Sponsored by: Auxito
Camshaft Syncronizer...Need help!!!
Old Aug 4, 2009 | 05:54 PM
danielhv's Avatar
danielhv
Ok, so I had a squeal in the engine, replaced the camshaft sync and its gone... prob is there is a timing problem... usually only noticeable at hwy spds on occasion, and when u are wot right b4 it shifts gears... I followed the directions as far as reinstalling (TDC, used alignment tool, etc). Now for my question... How to I tell if Im a tooth off, or if the sensor part itself isnt in the right spot?
Old Aug 4, 2009 | 09:10 PM
pintopower8's Avatar
pintopower8
This is a very confusing post, I would suggest starting from the original problem and going through your steps to where you are now.
