Rear liftgate doesn't open?
Old Aug 3, 2009 | 05:11 PM
TexFinn's Avatar
TexFinn
Yup... My wife just came back from getting groceries and when she started to unload the stuff from the back, the liftgate would not open! WTF???
The glass opens and closes properly, but the whole door does not open. You can hear the lock mechanism working when you press the buttons on the remote, but when you pull from the handle, nothing happens. The pulling resistance on the handle feels pretty normal so I don't think anything is broken there in the mechanism. Maybe... Hopefully...
As if I didn't have enough to-do with the emergency brake already.
Any and all help is again greatly appreciated.
Old Aug 3, 2009 | 05:55 PM
alloro's Avatar
alloro
Are you turning the handle the correct way?
Old Aug 3, 2009 | 06:40 PM
TexFinn's Avatar
TexFinn
No turning of handle on the good ole' 04. Just grab and pull.
Old Aug 3, 2009 | 07:50 PM
alloro's Avatar
alloro
Originally Posted by TexFinn
Just grab and pull.
Apparently not!
Old Aug 3, 2009 | 08:37 PM
TexFinn's Avatar
TexFinn
Originally Posted by alloro
Apparently not!
Not today...
Old Aug 4, 2009 | 06:02 AM
shov76's Avatar
shov76
click the open/closed few times in a row. Maybe push in the rear hatch handle while someone else is doing the button pushes. When you get it open lubeup the latch really good. I don't know if thats the official fix but it worked for me
Old Aug 4, 2009 | 07:42 PM
TexFinn's Avatar
TexFinn
Thanks for the tips shov76. I'll have to try that and see what happens. I guess I'll have some time tomorrow since I finally got the emergency brake adjusted today so I have at least one item off my to-do list.
Old Aug 6, 2009 | 12:23 PM
TexFinn's Avatar
TexFinn
No go w/the clicking the locks open/closed repeatedly.
I guess I'll have to try to get the interior panel removed somehow so I could get my hands on the moving parts.
Any other suggestions?
Old Aug 8, 2009 | 03:36 AM
dalesatter's Avatar
dalesatter
I had the same problem on my 04 and it turned out to be a broken wire in the harness down by the drivers left foot under the carpet.
Old Aug 8, 2009 | 03:00 PM
TexFinn's Avatar
TexFinn
Damn! Then again, I can hear the locks working, so I'm suspecting something happened to the handle mechanism.
It's just too damn hot to go outside and work on it so have been putting it off, but soon the wife is really going to kill me unless I fix it...
Old Aug 8, 2009 | 06:39 PM
bc11's Avatar
bc11
Maybe crawl in back and try some pressure with your feet on the door while someone tries the locks and the handle. Or try alternating pushing on the door and letting off and try to jiggle the latch while someone is unlocking and pulling on the handle. You might be able to remove the door panel without having it open.
Old Aug 8, 2009 | 09:32 PM
TexFinn's Avatar
TexFinn
None of the wiggling and jiggling wouldn't have helped since the cable from the handle to the release lever is broken.
I finally bit the bullet and removed the two plastic screw thingies where the glass lock and wiper motor are, the pull handle from the middle and started pulling the panel off. That sum'bitch was tight as hell but I finally got it off and found out that the cable was broken from the pull handle's end.
So..., the the stealership I go on Monday, I guess...
Old Aug 12, 2009 | 05:10 PM
TexFinn's Avatar
TexFinn
$26.75 for the cable, ~5 minutes to install that and put the interior panel back and we're good to go again.
Brent Riley
Nov 9, 2017 06:58 AM
salazar44
Jan 2, 2017 02:48 PM
New Hire
Aug 24, 2013 08:03 AM
Antonb3
Feb 2, 2013 06:37 PM
JADA
Nov 9, 2010 08:35 PM
