Sponsored by: Auxito
O/D off light flashing
Old Aug 2, 2009 | 09:23 PM
jdcpjc's Avatar
jdcpjc
Exclamation O/D off light flashing
Can anyone tell me why the O/D off light on the dash is flashing??? Whats it mean? Its a 2000 ford explorer...4.0 V-6
Old Aug 2, 2009 | 09:35 PM
pintopower8's Avatar
pintopower8
Your transmission has an error code. It would be a very smart idea to have your local dealer take a look.
Old Aug 2, 2009 | 09:39 PM
jdcpjc's Avatar
jdcpjc
Alright thank you....it seems to be running fine though.....
Old Aug 2, 2009 | 10:05 PM
bc11's Avatar
bc11
On my 2000 f150 5.4l 4x4 I ran over a log and jumped up and smashed the wiring harness along the frame rail into a body bracket behind the left front wheel. It cut or smashed most of the wires. It caused the od light to flash. That harness fed the fuel pump, rear lights, and the sensors and switches for the tranny and the rear end. Also blew the blue front fuse on the fuse panel under the hood. When I cut and put all new butt connections on the wiring, it would run but not in 4x4 high, had to go into 4x4 low, and the od light was still flashing. Through help on this board, I found the blown fuse and that fixed it. Someone said you can count the flashes in sequence to learn the code but mine didn't do that, it was just a steady on/off flash.
Check your fuses and then check the wiring going to your tranny and rear end. Could be something knocked a wire loose or pinched a wire or maybe water rusted a connection or maybe a bad ground somewhere. Let us know what you find out.
Old Aug 3, 2009 | 06:01 AM
projectSHO89's Avatar
projectSHO89
Wow!
Just go get it scanned. The computer will tell you what it is complaining about.
Old Aug 3, 2009 | 06:47 PM
pintopower8
Don't even bother screwing around with automatic transmissions, you can make things worse. You could have a problem that the computer is compensating for and you wouldn't even know it. Either way bite the bullet and get it checked out, you don't want a simple fix to turn into a rebuild.
Old Jul 6, 2012 | 09:58 PM
jdcpjc's Avatar
jdcpjc
I have a 2002 Ford Explorer and its been overheating. I've replaced the thermostat and the housing for it...fan clutch and water pump. Still overheats at high RPM's. What can I check on now?
Old Jul 7, 2012 | 12:11 AM
Bluegrass 7's Avatar
Bluegrass 7
Radiator partial plug.
Cap.
Air left in the system.
Good luck.
Old Jul 7, 2012 | 07:53 AM
jdcpjc's Avatar
jdcpjc
02 Ford Explorer
How can I check for a plugged radiator?
Old Jul 7, 2012 | 12:49 PM
projectSHO89
Why are you posting in this section, in this old, unrelated thread???
thegreatgate
Aug 25, 2016 06:01 PM
RDockery
Apr 21, 2016 08:50 PM
BAJI26
Apr 5, 2016 04:09 PM
snaponprofile
29
Apr 17, 2011 01:27 PM
Vinford
Jan 27, 2009 05:03 PM
