Sponsored by: Real Truck
04 4r100
Old Aug 2, 2009 | 08:35 PM
suzuki0702's Avatar
suzuki0702
Unhappy 04 4r100
nobody seems to hang around in the clutch, trans forum anymore. posted there with no luck so heres my second goround!
heres the history. vehicle bought used with 19k miles, change trans fluid every 40k due for change within days (already have fluid changing tommorow) truck has 76k miles now. 04 f250 few problems ill start with this one
seems whether in pulling a trailer or not, trans doesnt want to downshift from third to easily. i really have to step on it to get it into second. how to fix?
- tq conv. locks up in second gear sometimes when im really stepping on it??? thought that 3rd and od only had lockup. then when it shifts to third, its already in lockup, it doesnt lockup before it shifts to od.
- brake pedal doesnt unlock tq. conv. as ive read it should. also when i have od off, itll chug down a hill, as if the converter is always locked. but the minute i push the od on button, no matter what gear im in, the rpms drop as if the converter unlocks. but this doesnt affect the brake pedal.
no codes no flashing lights. please help! <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
__________________
Old Aug 3, 2009 | 08:18 AM
dkf's Avatar
dkf
Anytime you get off the gas the TQ should unlock with the stock tuning. The TQ will ockup in 2nd but it takes a while. Most don't notice lockup in 2nd because they don't spend enough time in 2nd. Going from 2nd to 3rd, 3rd to 4th and etc the TQ should unlock everytime it shifts and then lockup again. To knock down to second sometimes you have to give it some throttle.
Might want to have the trans shop doing the fluid change check for codes in case your scanner isn't seeing them, which is possible.
Old Aug 3, 2009 | 03:01 PM
suzuki0702's Avatar
suzuki0702
i did the mark kovalsky change. cooler return line method. sounds like normal operation then. thanks!
hp246
15
Jun 12, 2009 03:12 PM
Eddiestruck
May 5, 2009 04:18 AM
78F150RangerXLT
Mar 22, 2009 01:56 PM
quietman
Mar 7, 2009 09:36 PM
2horses
Feb 25, 2009 04:12 PM
