Sponsored by: Real Truck
Steering Damper question
Old Apr 22, 2009 | 10:00 PM
glepore's Avatar
glepore
I just picked up a stock steering damper and mounting bracket for my recently purchased 1999 F-250 Super Duty. Does anyone have a link or directions for installing this on my truck?
Thanks!
Old Apr 23, 2009 | 09:58 AM
ReAX's Avatar
ReAX
It should be pretty straight forward. If your drag link (the one that goes across the front end) has the two grooves, mount the mount where it locks into them. Install the dampener between this mount and the axle/frame mount.
Old Aug 3, 2009 | 03:38 PM
brian42's Avatar
brian42
Veteran: Navy
The tie rod bracket should fit fine. Your tie rod will have 2 sets of grooves that the u-bolts will fit in (the tie rod is too thick for the u-bolts to fit around. On my 2003, the u-bolts go on the set that is the driver's side of the 2 grooves. As for the bracket next to the wheel, I don't know if it's part of the steering assembly or if you can bolt that on too.
