6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Subwoofer ?
Old Aug 1, 2009 | 08:31 AM
raysbigfish's Avatar
raysbigfish
Subwoofer ?
I am like to get some subs for my 2009 F-250 crew cab. one guy told me ,use a box behind the rear seat with 2 10" kickers . He says I can only get a shallow sub. and the sound quality is limited . I dont know what to get. I like quality sound, not that jungle , distorted bass. Please help.
Old Aug 1, 2009 | 09:33 AM
gwcon's Avatar
gwcon
I remember reading a helpful post regarding SWers maybe about a month ago. You may want to do a search for it. Hope this helps.
Old Aug 1, 2009 | 11:32 AM
ruschejj's Avatar
ruschejj
If you look in my gallery you can find a pic of my Kicker 10" sub behind the rear seat. It's not pretty, had to cut the carpet and sound deadener to get it to fit. Sounds very good though.
Old Aug 2, 2009 | 08:10 PM
Reave1's Avatar
Reave1
I would reccomend a box that goes under the rear seat so it can be ported to create a bandpass box. The bandpass will give clear bass with low OHM levels. MTX makes thunderforms specifically deaigned to fit in the superduty unde the rear seat without looking gypsy. The boxes that go behind the seat work well, but can't move enough air to really hit. Just my .02
Old Aug 4, 2009 | 06:33 PM
Bobby82490's Avatar
Bobby82490
I seen a 08 the other day that they made the console into the sub box. Obviously the console wouldnt hold anything else anymore, but it looks very clean when done properly. He had 1 12" JL W3 in the console facing backwards plus many other goodys, it sounded really good.
Old Aug 4, 2009 | 06:39 PM
mountaineer27's Avatar
mountaineer27
i have a box i built custom. you can make it thin to fit behind the seat but you need to make it longer. as long as you have the right cubik ft of air in the box your good. i built mine ported with one JL 10 inch and 250 watts of power and its so bad you cant breath with the windows down. its got way more base than my buddies ranger with two 12 alpine r12's with a closed box and 1000 watts. its all in the set up of the box to the sub and just the right watts to the sub.
Old Aug 7, 2009 | 10:52 PM
LaxPlaya21's Avatar
LaxPlaya21
I have been out of the stereo game for a good ten years now, however back in the day in my hopped up Toyota... I had a 2 10" Solobaric Kickers, in a sealed enclosure. This was by far the cleanest, tightest bass I have heard in my day. It didnt blow your back out like some bandpass setups. Think about the goals you are trying to achieve with your stereo and then it will be easier to pick equipment.
bkpackerfan
Jan 27, 2013 09:01 PM
DBSweeney
Jun 5, 2007 08:34 AM
rustynuts
Feb 27, 2006 10:23 PM
nosfrog
2004 - 2008 F150
Apr 8, 2005 07:34 PM
bevo9604
Sep 17, 2003 01:03 PM
