Sponsored by: Innova
04 SD Crew 3 10" sub box
Old Feb 26, 2006 | 12:16 PM
rustynuts's Avatar
rustynuts
Has anyone made a sub box that holds three 10" subs for behind the fold down rear seat? Would like to run 3 JL subs. Open to other ideas, but I want really good sound quality and I want to shake the hairs on my neck. Thanks
Old Feb 26, 2006 | 06:20 PM
BSEXTON's Avatar
BSEXTON
I have box with 2 JL subs. It could fit a third had I wanted it. It is a very snug depending on which model of subs you use. I had to remove the internal liner that was on the wall along with the plasitc covers that go over the vents in the back of the cab. I used some dyna-mat to seal them back up. It turned out pretty sweet and the box looked like it was a stock piece when I was done. My seats will still pull forward but the bottom of each rubs the box as it is moved so I dont move them unless I have to .
Old Feb 27, 2006 | 10:23 PM
SD 4 me's Avatar
SD 4 me
subs
Rockford fosgate is coming out with shallow mount subs. They are about half as deep as the standard P3. They will fit for sure. I have two infinity 10s in mine and although they fit tight against the back I could easily put three in my 04
bigmandan50
Mar 7, 2007 08:05 PM
DamageFactor
Jul 11, 2006 11:19 PM
nosfrog
2004 - 2008 F150
Apr 8, 2005 07:34 PM
rangerxlt02
Aug 3, 2004 02:13 PM
regd the vedg
Oct 26, 2003 10:31 PM
