Sponsored by: Auxito
Squeel Under The Hood
Old Aug 2, 2009 | 02:45 PM
backdraft529's Avatar
backdraft529
i went out and looked and found a green cap on the end that says EVAP on it. that runs behind that cylinder that is attached to the firewall with 2 little bolts. i suppose i have to take them 2 bolts out to get that cylinder away from the firewall so i can see what i'm doing so i can see if the hose is bad or whats going on.
Old Aug 2, 2009 | 03:34 PM
cmorningstar01's Avatar
cmorningstar01
Just disconnect the hose from the EVAP and plug it (temporarilly) to see if that cures the noise problem.The hose runs from the underside of the intake manifold near the throttle body, If your hose is anything like mine was it will be very pourous and deteriorated and leave black residue on your hands.
Val
Old Aug 2, 2009 | 04:01 PM
backdraft529
i took that off the firewall. there is a hose coming from across the engine and into the cylinder that says gas/fuel and there is a hose that comes from somewhere below/behind the cylinder. i'm guessing its the one coming from behind/below the cylinder and yes it is very dirty. so i should just disconnect that and plug it with something and see if that stops the noise?
Old Aug 2, 2009 | 04:02 PM
backdraft529
what should i plug it with?
Old Aug 3, 2009 | 12:03 AM
backdraft529
had a guy look it over and he said the noise is coming from the torque converter at the transmission. he says it low in transmission fluid. does that make better sense?
Old Aug 31, 2009 | 06:34 PM
indcoltsfan32's Avatar
indcoltsfan32
What did you find out about the squeel?
Old Sep 1, 2009 | 06:27 AM
backdraft529
still checking but a friend of mine looked at it and said it was coming from the torque converter in the transmission so that is all i know. any suggestions?
Old Sep 1, 2009 | 06:47 AM
cmorningstar01
You indicated that the sound continues for a short time after the truck has been shut off, If this is the case then I would be doubtful about the torque converter unless it is a very short(less than 1 second)amount of time, Try using a mechanics stethoscope to see if you can locate the sound, Also if you suspect low trans fluid levels check and add fluid as necessary and see if that eliminates sound.
keep us posted
VJ
rdeanw
1997 - 2003 F150
Aug 30, 2010 10:18 PM
RedRum'05
16
Jun 14, 2010 12:00 AM
kylesmith000
Jan 28, 2008 05:52 PM
97Handshaker
1997 - 2003 F150
Aug 13, 2006 05:18 PM
jstutz101
Modular V10 (6.8l)
Apr 7, 2006 05:19 PM
