A/C switch inop
Old Jul 31, 2009 | 07:14 PM
2005REDFX4's Avatar
2005REDFX4
A/C switch inop
Hey guys,
I bought my 05 used with about 43k miles. I noticed shortly after that the #3 setting on my airflow switch didn't work. But I ignored it and now #1 and #2 also have quit. #4 blows good (well as good as it can judging by all the other posts). I called the dealer and he said sounds like the resistor. I would think maybe the switch is bad but I'm not sure how the switch is set up. If it has little contacts like on it or if the switch is bad it just dies all the way. So, if it is the resistor, how do I change it and if not is it worth $200 for the dealer to do it since my extended warranty doesn't cover it. You guys have been great with my other posts. Thanks.
Old Jul 31, 2009 | 07:46 PM
wildcard30's Avatar
wildcard30
Your blower motor resistor pack is gone. It's located behind the glove box. They're about 20 bucks at the dealer.
Old Jul 31, 2009 | 08:33 PM
2005REDFX4's Avatar
2005REDFX4
Thanks abunch. I'll try it. lot better than $200.
Old Aug 15, 2009 | 01:10 PM
2005REDFX4's Avatar
2005REDFX4
Ok I picked up the part for $31 which is not bad. I pulled the glove box down and I don't see anything that looks similar to the resistor pack. Any more help would be appreciated.
Old Aug 16, 2009 | 07:06 AM
wildcard30's Avatar
wildcard30
412-01-1 Climate Control 412-01-1
REMOVAL AND INSTALLATION
Blower Motor Resistor
Item Part Number Description
1 19A706 Blower motor resistor
2 W701696 Blower motor resistor screw
(2 required)
3 18B574 Blower motor resistor
electrical connector
Removal and Installation
1. NOTE: The blower motor resistor can be
accessed from below the RH side of the
instrument panel.
Disconnect the blower motor resistor electrical
connector.
2. Remove the 2 blower motor resistor screws.
3. Remove the blower motor resistor.
4. To install, reverse the removal procedure.
Hope this helps.....
Old Aug 18, 2009 | 08:42 PM
2005REDFX4's Avatar
2005REDFX4
Ohhh. Such a non-mechanic I am. Thanks man. I found it.
classic.rocker978
Jun 20, 2014 09:33 AM
hockeyguy1134
Nov 12, 2013 11:50 AM
8525ford
Aug 24, 2009 08:51 PM
884x4broncoII
Aug 18, 2009 03:51 PM
