Ignition circuit / resistor problems
Old Nov 6, 2013 | 11:41 AM
hockeyguy1134's Avatar
hockeyguy1134
Hey guys,
I have a 72 highboy with a 360 and have been having some trouble with the ignition recently. So if you have a minute I'll start from the beginning
So, started running really rough one day, missing like crazy, was looking around in the engine then all of a sudden the cab was full smoke. After a slight panic of turning key off/grabbing fire extinguisher/ disconnecting battery things cooled down with nothing actually catching fire.
So looking into it, found PO had cut Pink resistor wire after connector (outside of firewall), tapped into a light blue wire (attached to same connection at ignition switch) to run an external resistor (reads ~3 ohms) to the coil and starter relay. He also had a wire going to a tach before the resistor. Not positive that his setup was correct, or it might have had one bad connection, cause wire burned up all the way to the ignition switch.
So i took the tach out of the system and re-wired everything else with a new resistor (1 ohm, was what i had and figured it was closer to the stock measurement, havent measured voltage across coil yet) but engine is still hardly firing on any cylinders, barely runs.
Also, PO put in a mallory dual point, i accidentally broke one the posts on the coil (think it was a higher output coil for the dual point) so i threw the original back on. I have another used coil as well but not positive that either of these are good. I have original dizzy i can throw on too
Sorry if this is too much,
main questions are
1. Are the dual points still going to work with stock coil?
2. Is there any way to check coils to see if they're good?
3. What is actual resistance in circuit supposed to be (I've read/heard 1.3-1.4 ohms)
4. What is actual voltage at coil supposed to be? (I've read/ heard ~7 volts)
5. Any ideas why my setup wouldn't be working? As far as I can tell wiring is back to stock just using resistor instead of resistance wire
Old Nov 6, 2013 | 02:42 PM
Freightrain's Avatar
Freightrain
Yes a stock coil will work with dual points.
Yes, you should be able to read the resistance across the + and - terminals after you take the wires OFF the coil. Can't read resistance with wires on the terminals.
Typically the voltage at the coil should be around 9V while running.
I would swap distributors to a known good one(stock?) and see if things improve. Could be the points are bad/out of adjustment or the condensor is bad in the dual point version. Have you inspected the points? Have you checked the gap on each set?
Old Nov 6, 2013 | 04:38 PM
JEFFFAFA's Avatar
JEFFFAFA
I thought coil should be seeing 7 to 8 volts with the switch in the run position. Depends on which coil you use though. Some have the resistance built in to them so you would want 12v at the coil. But in either case I think it was the ignition switch that caused your problem. If I am correct neither dizzy set up will run good untill you change it. Original ignition switches caused exactly what you described. That is why the raplacement has different terminals and comes with a wiring pigtail to adapt it to your truck. Part number is D1AZ11572C. Still available from Ford.
BTW, if the coil you use does need to see the lower resistance I would buy a new resistance wire and go back to original. Part number was COLF12250A. It's cheap. Call these places to get the best deal. There are more if you need. Let me know.
<TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse; EMPTY-CELLS: show" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXMainTable class="dxgvTable tableStyle" border=0 cellSpacing=0 cellPadding=0><TBODY><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXHeadersRow><TD style="BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXTGScol0 class="dxgvHeader headerStyle locate-results-location-col" title="Selling dealership's location"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Location</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 90px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXTGScol1 class="dxgvHeader headerStyle" title="Distance from selling dealership to my dealership"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Distance</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 65px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXTGScol2 class="dxgvHeader headerStyle" title="Selling dealership quantity on hand"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>QOH</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 110px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXTGScol3 class="dxgvHeader headerStyle" title="Date/Time selling dealership inventory last updated for D2DLink"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Updated</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 120px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXTGScol4 class="dxgvHeader headerStyle" title="Selling dealership advertised discount on D2DLink"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Discount</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 120px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXTGScol5 class="dxgvHeader headerStyle" title="Selling dealership's phone number"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Phone</TD></TR></TBODY></TABLE></TD><TD style="BORDER-RIGHT-WIDTH: 0px; WIDTH: 30px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px; CURSOR: default" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXTcol6 class="dxgvHeader headerStyle addElementHeader"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD> </TD></TR></TBODY></TABLE></TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow0 class="dxgvDataRow rowStyle"><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell0_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>Griesel Motor Inc
(Okarche, OK) </TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" class=dxgv>804</TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell0_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell0_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">11/3/2013</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell0_4 class=dxgv></TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell0_5 class=dxgv>(405) 263-7242 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell0_6 class="add-element-cell dxgv"> </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXPRow0 class="dxgvPreviewRow dxgvDataRow rowStyle"><TD class=dxgv colSpan=6>There's no returns on obsolete parts.</TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow1 class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell1_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>Bob Allen Ford
(Overland Park, KS) </TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" class=dxgv>1,030</TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell1_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell1_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">9/6/2013</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell1_4 class=dxgv></TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell1_5 class=dxgv>(913) 381-2999 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell1_6 class="add-element-cell dxgv"> </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXPRow1 class="dxgvPreviewRow dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD class=dxgv colSpan=6>We ship on OPEN ACCOUNT to FORD Dealers! 913-381-2999. YOU CAN ALSO FAX YOUR ORDER TO 913-383-2947. WE BUY INVENTORY!!! Ask for details.</TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow2 class="dxgvDataRow rowStyle"><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell2_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>Kinsel Lincoln Mercury
(Beaumont, TX) </TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" class=dxgv>1,062</TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell2_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell2_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">10/31/2013</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell2_4 class=dxgv></TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell2_5 class=dxgv>(800) 816-2894 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell2_6 class="add-element-cell dxgv"> </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXPRow2 class="dxgvPreviewRow dxgvDataRow rowStyle"><TD class=dxgv colSpan=6>We ship OPEN ACCOUNT to all Ford L/M Dealers C + 10%. ALL DEALERS CALL (800) 816-2894 OR EMAIL GGARZA@KINSELAUTOMALL.COM ... GINA'S WAITING FOR YOUR CALL !!!! </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow3 class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell3_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>Smackover Motors Inc
(Smackover, AR) </TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" class=dxgv>1,099</TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell3_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell3_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">11/6/2013</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell3_4 class=dxgv></TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell3_5 class=dxgv>(870) 725-3961 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell3_6 class="add-element-cell dxgv"> </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow4 class="dxgvDataRow rowStyle"><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell4_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>Lyle's Ford, LLC
(Eagle Grove, IA) </TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" class=dxgv>1,164</TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell4_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell4_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">11/6/2013</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell4_4 class=dxgv></TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell4_5 class=dxgv>(800) 397-6319 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell4_6 class="add-element-cell dxgv"> </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXPRow4 class="dxgvPreviewRow dxgvDataRow rowStyle"><TD class=dxgv colSpan=6>ASK FOR WALLY IN PARTS FOR ALL YOUR PARTS NEEDS. SAME DAY SHIPPING IF YOU CALL BEFORE 4:00 PM CST. CALL 800-397-6319. NO RETURNS ON ELECTRICAL OR OBSOLETE PARTS. ASK FOR PERTINENT DISCOUNT WHEN INQUIRING ON PARTS.</TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow5 class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell5_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>Soeby Motor Company
(Walhalla, ND) </TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" class=dxgv>1,291</TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell5_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell5_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">11/6/2013</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell5_4 class=dxgv></TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell5_5 class=dxgv>(701) 549-3711 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell5_6 class="add-element-cell dxgv"> </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow6 class="dxgvDataRow rowStyle"><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell6_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>STERNBERG FORD
(Dale, IN) </TD><TD class=icon-column> </TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" class=dxgv>1,427</TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell6_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell6_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">3:58 AM</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell6_4 class=dxgv>Cost - 35% </TD><TD style="TEXT-ALIGN: left" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell6_5 class=dxgv>(812) 937-4241 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell6_6 class="add-element-cell dxgv"> </TD></TR><TR id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXDataRow7 class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD style="TEXT-ALIGN: left; BORDER-BOTTOM-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell7_0 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD id=cell4Icons class=icon-column></TD><TD>Jannell Motors, Inc.
(Hanover, MA) </TD><TD class=icon-column> </TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center; BORDER-BOTTOM-WIDTH: 0px" class=dxgv>2,296</TD><TD style="TEXT-ALIGN: center; BORDER-BOTTOM-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell7_2 class=dxgv>1 </TD><TD style="TEXT-ALIGN: left; BORDER-BOTTOM-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell7_3 class=dxgv><TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0><TBODY><TR><TD style="WHITE-SPACE: nowrap">11/5/2013</TD><TD class=icon-column></TD></TR></TBODY></TABLE></TD><TD style="TEXT-ALIGN: center; BORDER-BOTTOM-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell7_4 class=dxgv>Cost - 25% </TD><TD style="TEXT-ALIGN: left; BORDER-BOTTOM-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell7_5 class=dxgv>(781) 982-4510 </TD><TD style="TEXT-ALIGN: left; BORDER-RIGHT-WIDTH: 0px; BACKGROUND-COLOR: white; BORDER-BOTTOM-WIDTH: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_tccell7_6 class="add-element-cell dxgv"> </TD></TR></TBODY></TABLE> <TABLE style="WIDTH: 100%" class="dxgvStatusBar hidden" border=0><TBODY><TR class=dxgv><TD style="WIDTH: 100%"> </TD><TD id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXLPContainer></TD></TR></TBODY></TABLE><TABLE style="Z-INDEX: 30000; DISPLAY: none; BORDER-COLLAPSE: collapse; TOP: 0px; LEFT: 0px" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_LP class="dxgvLoadingPanelStatusBar detailsLoading" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD class=dx></TD></TR></TBODY></TABLE>
<TABLE style="DISPLAY: none" id=ctl00_oecStylePlaceholder_DealerResults_Results Grid_DXStyleTable border=0><TBODY><TR><TD></TD></TR><TR class=dxgvEditingErrorRow><TD style="BORDER-RIGHT-WIDTH: 0px" class=dxgv colSpan=7></TD></TR><TR class="dxgvSelectedRow rowStyle"><TD></TD></TR><TR class="dxgvFocusedRow rowStyle focusedRowStyle"><TD></TD></TR><TR class=dxgvFocusedGroupRow><TD></TD></TR><TR class="dxgvDataRow rowStyle"><TD></TD></TR><TR class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD></TD></TR><TR class="dxgvDataRow rowStyle"><TD></TD></TR><TR class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD></TD></TR><TR class="dxgvDataRow rowStyle"><TD></TD></TR><TR class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD></TD></TR><TR class="dxgvDataRow rowStyle"><TD></TD></TR><TR class="dxgvDataRow rowStyle dxgvDataRowAlt alternatingRowStyle"><TD></TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 100%; BORDER-COLLAPSE: separate" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View class=dxgvControl border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse; EMPTY-CELLS: show" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXMainTable class="dxgvTable tableStyle" border=0 cellSpacing=0 cellPadding=0><TBODY><TR id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXHeadersRow><TD style="BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTGScol0 class="dxgvHeader headerStyle" title="Selling dealership's location"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Location</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 150px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTGScol1 class="dxgvHeader headerStyle" title="Part Number"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Part Number</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 150px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTGScol2 class="dxgvHeader headerStyle" title=Description><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Description</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 60px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTGScol3 class="dxgvHeader headerStyle" title="Selling dealership quantity on hand"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>QOH</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 95px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTGScol4 class="dxgvHeader headerStyle" title="Selling dealership advertised discount on D2DLink"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Discount</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 100px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTGScol5 class="dxgvHeader headerStyle" title="Selling dealership's phone number"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Phone</TD></TR></TBODY></TABLE></TD><TD style="WIDTH: 50px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTGcol6 class="dxgvHeader headerStyle" title="Quantity Requested"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>Qty</TD></TR></TBODY></TABLE></TD><TD style="BORDER-RIGHT-WIDTH: 0px; WIDTH: 30px; BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px; CURSOR: default" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXTcol7 class="dxgvHeader headerStyle addElementHeader"><TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD> </TD></TR></TBODY></TABLE></TD></TR><TR class=dxgvEmptyDataRow><TD style="BORDER-BOTTOM-WIDTH: 0px" class=dxgv colSpan=8>No data to display
</TD></TR></TBODY></TABLE><INPUT id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXSelInput type=hidden name=ctl00$oecStylePlaceholder$LocateOrdersGrid$Gr idView$DXSelInput> <TABLE style="DISPLAY: none" id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_DXStyleTable border=0><TBODY><TR><TD></TD></TR><TR class=dxgvEditingErrorRow><TD style="BORDER-RIGHT-WIDTH: 0px" class=dxgv colSpan=8></TD></TR><TR class="dxgvSelectedRow rowStyle"><TD></TD></TR><TR class="dxgvFocusedRow rowStyle focusedRowStyle"><TD></TD></TR><TR class=dxgvFocusedGroupRow><TD></TD></TR></TBODY></TABLE><INPUT id=ctl00_oecStylePlaceholder_LocateOrdersGrid_Grid View_CallbackState value=/wEWBB4ERGF0YQWEA0FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBSEF BQUFERk4xY0hCc2FXVnlUbUZ0WlF4VGRYQndiR2xsY2s1aGJXV UhBQUVLVUdGeWRFNTFiV0psY2dwUVlYSjBUblZ0WW1WeUJ3QUJ EMUJoY25SRVpYTmpjbWx3ZEdsdmJnOVFZWEowUkdWelkzSnBjS FJwYjI0SEFBRUZVR2h2Ym1VRlVHaHZibVVIQUFFRVEyOXpkQVJ EYjNOMEJ3QUJFRk4xY0hCc2FXVnlVWFZoYm5ScGRIa1FVM1Z3Y 0d4cFpYSlJkV0Z1ZEdsMGVRTUFBUUpKWkFKSlpBc0FBUWNBQUF BRVEybDBlUTFUZEdGMFpWQnliM1pwYm1ObERVOXlaR1Z5VVhWa GJuUnBkSGtRVTNWd2NHeHBaWEpKWkdWdWRHbDBlUlJUZFhCd2J HbGxjazFoYm5WbVlXTjBkWEpsY2dwUVpYSmpaVzUwWVdkbEQxQ nlhV05wYm1kUGNHVnlZWFJ2Y2djQUJ3QT0eBVN0YXRlBWBCd2d IQUFJQkJ3RUNBUWNDQWdFSEF3SUJCd1FDQVFjRkFnRUhCZ0lCQ ndjQ0FRY0FCd0FIQUFjQUFnQUcvLzhKQWdKSlpBa0NBQUlBQXd jRUFnQUhBQUlCQndBQ0FRY0E= type=hidden name=ctl00$oecStylePlaceholder$LocateOrdersGrid$Gr idView$CallbackState></TD></TR></TBODY></TABLE>
<TABLE><TBODY><TR vAlign=center><TD></TD><TD style="PADDING-LEFT: 6px">Click to refresh inventory in real time.
Powered by ADP.</TD></TR></TBODY></TABLE>
<TABLE><TBODY><TR vAlign=center><TD></TD><TD style="PADDING-LEFT: 6px">Accessing real-time inventory data. Please wait...</TD></TR></TBODY></TABLE>
Old Nov 7, 2013 | 11:00 AM
hockeyguy1134
Thanks guys,
I remember hearing about bad ignition switches actually, on a 68 i think, same part? I'm getting a new one in tomorrow so ill let you know how that goes. (fifty bucks on amazon, not bad)
In the mean time i think ill do a carb rebuild, check my coils and put new points/cap/condenser on that stock dizzy and put that in...should run like new huh? haha
Old Nov 7, 2013 | 12:47 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by hockeyguy1134
Thanks guys,
Check that stock Dizzy 1st make sure it isn't worn out. May be why PO changed it. Check shaft in housing tightness, drive gear, Points breaker plate, etc. That D1AZ11572C is a replacement for a bunch of vehicles. Including Bumps. I still say think about putting the resistance wire back in there.
Old Nov 8, 2013 | 06:16 AM
Alex from GA's Avatar
Alex from GA
IMO, once you get a good distributor, install a Pertronix points replacement unit. Remove the resistor and run it. Put their coil on it also.
Old Nov 11, 2013 | 11:54 AM
hockeyguy1134
Hello all,
I got the ignition switch in but it didn't come with a connector/pigtail...
Maybe cause I got it online? If i get from ford it might but i cant tell until i buy it
Does anyone know a part number for just the connector or where i could find one?
Old Nov 12, 2013 | 11:50 AM
JEFFFAFA's Avatar
JEFFFAFA
Hello all,
The only way I've ever seen it serviced is in the part number switch I posted above. Buying the switch and pigtail separate will probably be more expensive than just buying the Ford one From a Ford dealer.
You might try your local parts stores. Painless wiring sell you one maybe?
sere0501
Jun 17, 2014 11:57 AM
mainegoatman
29
Sep 10, 2012 01:25 AM
Aaron-71
Electrical Systems/Wiring
Jul 22, 2012 02:07 PM
lbrauer
Jun 16, 2010 09:51 PM
