'05 F150 FX4 dies while braking to a stop
Back in May my truck suddenly died when coming to a quick stop. It did it two more times that trip and since then when the truck is hot (not overheating), when the temp outside is hot (here in Texas) it will die while braking to a stop almost without fail - after running about 30+ miles. Also, lately the transmission will do occasional hard shifts at unexpected times and I also hear some knocking or plinking noises at times under the undercarriage while driving. Another thing is the idle seems very low - around 550 at a dead stop whenever it doesn't die. Any ideas? It's not putting out any codes and all systems seem normal. I'm thinking either a throttle position sensor or a vacuum line issue to the transmission.
The dealer let me have the truck with a "flight recorder" installed on it. All I had to do is press a button when the problem occured. Two days later it did and I pressed the button. This time the truck actually had the check engine light on aso I knew a code was registered. I was 35 miles from the dealer, but I drove straight there and turned the truck over to them. They ended up replacing the throttle body and I was happy, but two days ago the truck died on me again and then the next day the transmission was acting up in cruise control - several little hitches or jumps at a time. I guess I'll have to take it back.
Okay. I think it's fixed now. After putting it in the shop for the third time, same problem the mechanic found a wiring harness that was pinched in between an A/C line and the valve cover and had rubbed throught the protective sleeve covering the harness and had rubbed through the wire pair that goes to the "crank position sensor" or "crankshaft position sensor". Apparently the cold A/C line in hot weather condensed enough moisture in hot weather that it grounded the wire and would cause the problem. I'll be driving a lot this week and will know if it got fixed.
jmccart
10-10-2023 03:16 PM
NC F150
12-18-2016 01:38 PM
