Oil & Lubrication
Lube Question: Steering Linkage
Old Jun 28, 2002 | 02:17 PM
Quikirk's Avatar
Quikirk
Can anyone tell me what type of grease to use on the steering linkage, '02 SD. Is it ok to mix mine with whatever Ford used. I have an all purpose wtr resistant grease made by Polaris that I use on ATV's. Is this ok? Thanks.
Old Jun 28, 2002 | 03:07 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
It's probably fine. A steering linkage is not a specialty application. Water resistant grease is a good choice. If you want to be absolutely sure, look up the component lube specifications in the back of your owners manual. It will tell what to use and give the Ford specification number. Then find out if that grease meets Ford's spec's.
Old Jul 9, 2002 | 07:36 AM
LK's Avatar
LK
Old Jul 15, 2002 | 12:51 AM
Ryan50hrl's Avatar
Ryan50hrl
I've had really good luck with the mobil 1 synthetic grease. The boot on my tie rod got torn off almost a year ago now, and i've been greasing it with the mobil about once a month, and watching for wear, its still tight, after getting soaked, muddy, frozen over winter,,,I'll probably change the tie rod just so i don't have to worry about it, but it seems to work well.
Ryan
cdherman
2004 - 2008 F150
Sep 23, 2018 08:59 AM
Laggy
Jun 16, 2017 05:04 AM
Mike1
Nov 8, 2016 02:02 PM
ddmnam
Oct 13, 2009 08:43 PM
sportscar
Feb 5, 2006 10:08 AM
