CCV reroute predicament
Old Jul 31, 2009 | 12:45 AM
joe blow's Avatar
joe blow
I made a mistake....I used 5/8"...I just remembered.
Old Jul 31, 2009 | 12:50 AM
bismic's Avatar
bismic
I actually went up to 1" hose w/ my new installation, but I really do think 3/4 inch is fine. I will do a pressure drop calculation on a 5/8 inch hose and 10 cfm tomorrow at work (I hope I remember). I assume it is about 10 feet total (plus the filter)?
Old Jul 31, 2009 | 12:51 AM
joe blow's Avatar
joe blow
It's about 10' or so.
Hey bis...what kind of work do you do if you don't mind me asking?...You always have the answers brother!
Old Jul 31, 2009 | 12:58 AM
bismic's Avatar
bismic
I am an Engineer (at least until the next layoff). I appreciate the compliment, but most of my answers come from spending time w/ the Ford literature that I have accumulated (and been given by several gracious people on various sites).
Old Jul 31, 2009 | 12:59 AM
joe blow's Avatar
joe blow
Thanks for taking the time Mark...I really appreciate it!
Old Jul 31, 2009 | 06:57 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
IMO your 3" PVC is too small for the job and the filter media is inadequate...which is why your getting blow-by even though some of it is getting picked up in your canister. Opening the petcock will relieve the pressure, but its almost the same as venting to the atmosphere. To be emmissions freindly (in other words to avoid any hassle from environmentalists or emmissions inspections bubbas) the ccv filter is the way to go...closed system. I would get a bigger system and keep it closed. I picked up a Racor CCV 6000 filter assembly off ebay (new in box included filter element) for $80. It was listed as a Caterpillar part number 280-4015...I checked with Parker on whether it indeed their part and they said yes. I did call two local CAT parts distributors in my area and they listed the part at $603.00 and $593.12...so, pretty decent savings if you want to do this mod. There out there...check out ebay. Good luck with the mod.
Old Jul 31, 2009 | 07:01 AM
MoyockPowerstroke
Joe, check out ebay item #270403083748...here ya go!
Old Jul 31, 2009 | 10:29 AM
joe blow's Avatar
joe blow
Thanks alot I will check on it ASAP
Old Jul 31, 2009 | 03:02 PM
npccpartsman's Avatar
npccpartsman
I had one from NC hornet also and disconnected it very very quickly. It made my truck blow blue oil smoke out the tail pipe. After talking to a tech that recently removed one (within the past 3 days) he said that the crankcase pressure was extremely high with the CCV mod through the canister. I have been having an on going argument with a tech friend of mine who is totally against this mod. He's worked on powerstrokes for 17+ years, seen trucks with 400K+ miles running tuners and has NEVER seen a problem with running the oil through the intercooler. Mine is back to stock and my blue smoke disappeared at the tail pipe. I have one for sale cheap if someone wants it.
Old Jul 31, 2009 | 04:22 PM
joe blow's Avatar
joe blow
I am going to leave the petcock open.
Old Jul 31, 2009 | 05:27 PM
bismic's Avatar
bismic
The crankcase pressure will be a function of the "blow-by" you have and the pressure loss in the crankcase vent system. For the horsepower of our engines (and an assumed 10 SCFM vapor load in the CC vent) the back pressure will be about 2 psi for a 3/4 inch hose. The back pressure will be 0.4 psi for 1 inch hose. Joe - the 5/8 inch hose is too small IMO - even if you leave the petcock valve open. I will say that a 10 SCFM vapor load is a high flow rate, usually seen w/ older engines.
I do not believe that 0.4 psi is an issue, so I will probably keep my system. I had no observable negative affect w/ my filter (ie no smoke, no oil loss, no pressure at the dip stick).
npccpartsman - what size hose did you run when you had the system installed? Much of the pressure drop is in the hose. I do believe though that the filter from NC Hornet may be too small if you have much "blow-by".
You can get a pressure gauge and "tube it up" to your dip stick tube to measure the crankcase pressure.
Old Jul 31, 2009 | 09:20 PM
joe blow's Avatar
joe blow
It almost seems that the best thing to do is vent it to the atmosphere and be done with it.....aside from the leaks. Now that I disabled my EGR valve, I may even return it to stock....Not quite sure yet. I knew that thing was a POS when I first opened it.
Old Jul 31, 2009 | 09:50 PM
  #28
bismic's Avatar
bismic
Joe - from my calculations, I am SURE that the 1 inch hose and the ccv6000 will not backpressure the crankcase. I will test it tomorrow (I need a 10' section of hose to get my pressure gauge connected to the dipstick tube and run to the cab). I will be able to see as low as 1 psig (and can see vacuum if there is any). I will post the results.
My intake is definitely clear of oil from the mod. I am still convinced it is a good mod.
Old Jul 31, 2009 | 09:52 PM
  #29
npccpartsman
I had a crankcase pressure test run last fall because I thought I had excess blowby but it was well within spec. I was running 1" hose, but the connections were only 5/8. The smoke from the tailpipe was constant with the canister hooked up. back to stock it complete disappeared. It was so bad I thought my turbo seals had gone out, but that was not at all the case.
Old Jul 31, 2009 | 09:57 PM
  #30
bismic's Avatar
bismic
This really sounds odd to me. What is your theory on how the oil was getting into the combustion system?
Also, do you know what is an acceptable crankcase pressure?
