a/c stops blowing
Old Jul 30, 2009 | 03:57 PM
jefxxo's Avatar
jefxxo
a/c stops blowing
OK, I haven't been driving it lately but when I do I notice that when im hitting close to 70 mpg The ac stops working, if i slow down I hear a thump and it kicks back in.... Do i have a vacume loose?? Any help would be great appreiciated. !!
Old Aug 1, 2009 | 08:20 PM
jefxxo's Avatar
jefxxo
*bump* anyone?
Old Aug 1, 2009 | 09:59 PM
johnboy427's Avatar
johnboy427
Does it stop being cold or does it actually stop blowing?
-Johnboy
Dobbinicus's Avatar
Dobbinicus
Could be the reduction in manifold vacuum that occurs when the throttle is opened sufficiently to achieve 70MPH. The blend door of the HVAC system is operated by vacuum. When the hammer is down on a tired motor, they sometimes don't have enough vacuum to keep the blend door in the position that directs air towards the panel vents. If when the AC "stops blowing" you can feel it coming out of the floor and defrost vents and when you slow down the air comes back out the panel you'll know... The blend doors default to defrost/floor sans vacuum.
Old Aug 2, 2009 | 12:40 AM
jefxxo's Avatar
jefxxo
You answered correct. Vents stop blowing and it moves towards the window and floors. Now where do i find the blend door motor?
Old Aug 3, 2009 | 10:17 PM
jefxxo's Avatar
jefxxo
*Bump* Anyone?
Old Aug 9, 2009 | 07:54 AM
timbersteel's Avatar
timbersteel
Also, just a thought...This maybe the white vaccum line that is on the passenger side, up near the cowl and the vaccum plunger that works the blend door switching.
Pop the hood and look into the wire loom just between the A/C Compressor and the Fender well. There should be a white vac line. Look/feel/inspect for crumbling hose or other deteriating spots in it. My A/C would do the same thing, and after searching for the problem, FTE members directed to the problem.
This is also covered in the 87-96 F-150 Sub-Forum here:
https://www.ford-trucks.com/forums/8...cuum-line.html
If this the problem, it is an easy fix.
Let us know what you com eup with.
Matthew
Old Aug 9, 2009 | 02:35 PM
notyettoday's Avatar
notyettoday
There is usually a big metal can under the hood on these which is the vacuum resevoir, my old lincoln did the same thing and it turned out the vacuum can had a hole rusted in it. if your engine isn't building enough manifold vacuum at 70 to keep the plungers in their position than thats another problem, but i'd check this can just to cover all your bases
Old Aug 10, 2009 | 09:19 AM
tomw's Avatar
tomw
Most Fords had a check valve in the system that kept vacuum high when intake manifold vacuum fell off. Examine the underhood vacuum line diagram, or trace the vacuum line from the intake to a manifold near the power brake booster. This check valve will prevent vacuum from leaking down, and allow for one or two boosted stops if the engine were to fail. It also keeps the heater from defaulting to 'defrost' when you accelerate hard.
tom
Old Aug 20, 2009 | 04:07 PM
A1C DiMaggio's Avatar
A1C DiMaggio
Matthew
timbersteel is right. had the same problem with my 95. i looked under the hood and the vacuum hose had dry rotted. i went to auto zone and got a section of vacuum hose just slightly bigger and put it on (less than $5). no problems since, its been over a year.
reamer
Oct 16, 2014 05:35 PM
Byf619
25
May 4, 2012 03:06 PM
big-papa
1997 - 2003 F150
Mar 29, 2011 09:09 PM
BGW
Oct 27, 2007 06:18 AM
97Handshaker
1997 - 2003 F150
Aug 13, 2006 05:18 PM
