300 I6 coming out!
Old Jul 29, 2009 | 01:10 PM
Tees77f150's Avatar
Tees77f150
300 I6 coming out!
I am about to pull the 300 I6 out of my 77 F150 custom Explorer. It is in desperate need of a rear seal, and the pan gasket is shot.
I have a engine hoist and and stand at the ready, a friend with chains, and plan on doing this with in the next week.
Everthing is unbolted from the moter except the torque converter, which I will do.
While it is out I plan on giving it a fresh coat of paint, and cleanig up the engine bay. It is, or was attached to a C4, which is still in the truck.
My question is, where, or how should I hoist this out? I am planning on leaving the intake and exhaust manifold attached is my plan.
I gues to clarity my question, I am planning on throwing some chains around the motor mounts, but don't know who to get a hold of the motor towards the rear.
I added a few pictures for you to view. Any thoughts or imput would be greatly appriciated!
PS: I will take some pictures of the event for all to see!
Old Jul 29, 2009 | 01:43 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
I would not advise pulling it out by the motor mounts without bringing the trans with it. You don't want this thing flipping forward or backward. If it were me, I'd pull the engine and trans by the motor mounts as a unit, using one of the bellhousing bolt holes to hook a chain up to. Use a longer grade eight bolt for this one.
This way, your weight will be balanced and you'll have a stable "tripod." You'll also have the trans out to detail and clean/ repaint along with the area under the truck!
JMO
Old Jul 29, 2009 | 01:56 PM
Holiver31's Avatar
Holiver31
I've seen engines pulled by taking the carb off and using an attachment to hook up to the intake manifold. How safe this is I do not know. Try to get 4 point to hook up to on every corner, lift it a couple inches before pulling it to check if it is wanting to tip over.
Old Jul 29, 2009 | 02:16 PM
Witty73's Avatar
Witty73
Probably not the correct way, but my bro and I have pulled these things out by wrapping a chain around the manifold.
Old Jul 29, 2009 | 06:00 PM
murph77's Avatar
murph77
I took a look in my manual, it said to use a "sling".
Kinda vague. I'd call the local Ford dealer on this one.
See if you can get some tips from the fellows who have done it a few times.
I'm curious to know myself. Let us know, show photos!
Murph.
Old Jul 29, 2009 | 06:18 PM
peganit2's Avatar
peganit2
The motor mounts are too low and your lift will be top heavy and want to spin upside down on you.
Find some 3/8 bolt holes on the head, roughly symetrically opposite each other on the sides of the head and attach your chain there. You should have to do some fine tuning on your bolt placement and where you hook your chainfall or cherry pickers hook to the lift chain to get the engine lifting straight up and out.
You can't use the intake, it's offset too far. That only works on V type motors.
What does the coil bolt to? That one may be high enough and it looks like there should be one on the intake side to balance it out with.
Is there a bolt in the back of the head, opposite the thermostat housing bolts?
Old Jul 29, 2009 | 11:04 PM
4x4 Bart's Avatar
4x4 Bart
As far as engines go these six's aren't too heavy but these engines are tall and long and do not balance good. I have used the front exhaust bolt hole on the passenger side.
On the drivers side it's a little more difficult to find a good hole towards the rear of the block to balance. I made a lift plate and bolted it to one of the rear lifter cover bolt holes but if you got too rough you might could break it off and be in trouble. It worked for me more than a few times but I can't recommend that it is 100% safe.
I wouldn't hesitate to use a lifting strap around the intake and exhaust manifold but then again you are a little off balance to the left.
I saw a manual one time that illustrated using two valve cover bolt holes on the passenger side.
These are tiny bolt sizes but I tried it. I used two good bolts with washers welded to the heads and it worked perfect with good balance but I was real nervous a lift bolt would break at the threads and drop the engine.
You could pull the carb and use one stud for one end of a chain, then on the other side use the coil mounting bolt hole. This would probably be the safest.
Be careful when setting these engines down and unhooking, they are very tall and can flip over in a heartbeat. A friend of mine was trying to unbolt a chain on the side of a six and it fell over and caught his arm and broke it in two places.
Old Jul 30, 2009 | 01:00 PM
Tees77f150's Avatar
Tees77f150
Thanks guys, a lot of good points made and well taken. Sometimes you just can't see the obvious when your in the thick of it. I will take pictures & post the results. I just found out my friend who was going to help is going away, so it looks like I will be delayed for another week. But I will post back in this thread when things start to happen!
THANKS AGIAN TO YOU ALL, YOU GUYS ARE A GREAT BUNCH!!
Tees77f150
31
Mar 6, 2020 02:18 PM
wmjoe1953
18
Jul 23, 2011 07:17 AM
Tees77f150
Aug 9, 2010 10:03 PM
Tees77f150
Mar 29, 2010 08:25 AM
Tees77f150
19
Apr 28, 2009 07:49 AM
