Sponsored by: Real Truck
Rear work light location???
Old Jul 29, 2009 | 12:34 PM
Downriver Thunder's Avatar
Downriver Thunder
On my 05 250 I got some new worklights, LED, from Grote. These are the new Trilliant lights, cost $310 each and hope they're worth it. Problem I have is that I want to mount these on the back of the truck for back up light but with my duals coming out on both sides of my hitch I can't mount them there. There's no lip on the bottom of the bumper, any other mounting ideas?
Old Jul 29, 2009 | 12:35 PM
Downriver Thunder
Here's a pic of them.
Old Jul 29, 2009 | 01:34 PM
pbeering's Avatar
pbeering
Remove the mounting bolt in the middle and attach the loop to the box tube on the hitch with a couple of large zip ties. Run a separate ground wire to the lamp head and you 'll be set.
Old Jul 29, 2009 | 01:41 PM
Downriver Thunder
Don't think that's a bit too low? I could zip a couple self tappers up in there too, don't tow much weight when I do tow, which I haven't in like 5 years.
Old Jul 29, 2009 | 02:36 PM
bpounds's Avatar
bpounds
Holy guacamole, that's some expensive backup lights!!!
I would not mount lights any lower than my trailer hitch. Doing so would be just asking to get them broken or torn off, even if you don't go off road. At $300 per, that would wreck my day. That leaves the area just outside the hitch, just below the level of the bumper. I would probably try to mount them off the hitch gusset.
If you search for the "stealth backup" thread, you will see a lot of examples of how guys have mounted BU lights.
Old Jul 29, 2009 | 02:45 PM
pbeering's Avatar
pbeering
Good point, don't hang them under the box tube, move the mounting bracket to the back of the lamp head and then affix it to the side of the box tube. That way it gets some protection from the bumper and won't get as much junk off the tires.
Old Jul 29, 2009 | 02:49 PM
Downriver Thunder
Good ideas. Although I didn't pay for them I wouldn't want to chance breaking them.
Old Jul 29, 2009 | 02:54 PM
bpounds's Avatar
bpounds
Here is the thread I mentioned:
https://www.ford-trucks.com/forums/5...with-pics.html
Old Jul 29, 2009 | 09:08 PM
BobbyDiesel71's Avatar
BobbyDiesel71
I would def recomend a HEADACHERACK(BACK RACK)
they have many lighting tabs for mounting different types of lights
Myyke
Jan 15, 2014 11:13 AM
02SuperPoop
Dec 29, 2013 09:54 PM
haese56
Nov 7, 2011 12:28 AM
Bill Nolan
2009 - 2014 F150
Jun 22, 2011 04:46 PM
DS02F250
Aftermarket Products
29
Feb 23, 2004 03:18 PM
