1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trans Slips When Remove-Then-Replace Foot On Accelerator ?
Old 07-29-2009, 07:53 AM
ironmine's Avatar
ironmine
ironmine is offline
2002 F250 5.4 Auto CC LWB 4X4; 109,000 miles
-IIRC, trans fluid changed twice by dealer, last time at approx 60,000
miles; IIRC, $69 ... so I guess just pan-filter/fluid changes, not flush-??
-I have a 4r100 trans - ????
-The transmission shifts gears fine ... smooth and crisp.
-The truck starts off from a stop fine.
-The problem is ..... when at high speed, or at least at high rpm, when you remove your foot from the accelerator pedal, and then press down on the gas again, there is a hesitation before the transmission grabs. The truck makes a "winding up" sound, and then transmission kicks in, and you start accelerating, etc.
-My son had borrowed the truck, and he was telling me this over the phone this morning. He will bring it to me this evening. I will check for any codes, examine the atf fluid, etc
-I asked him if the truck was trying to downshift and was having problems, he said no ... the truck is going too fast to want to downshift.
-It does not bang or clank when the transmission catches, or stops slipping ... whatever is going on here.
-Again, the transmission runs perfectly ... except when you remove your foot from the gas at high speed or high rpm, and then replace your foot while still at high speed or rpm.
Any thoughts?
Thanks.
Old 07-29-2009, 08:50 PM
ironmine's Avatar
ironmine
ironmine is offline
Bumping it for the evening crew.
Old 07-29-2009, 09:45 PM
aldridgec's Avatar
aldridgec
aldridgec is online now
AFAIK, this is normal behavior. When you let off the gas, the converter unlocks. When you get back on the gas it locks again. This will cause a flare and make it seem like it's slipping.
Old 07-30-2009, 07:00 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
This is exactly what's going on.
JL
Old 08-01-2009, 10:01 PM
ironmine's Avatar
ironmine
ironmine is offline
I thought it was the torque converter, too .... since the transmission shifts fine. Over days, it became harder and harder for it to lock back in.
Update ... I still don't have my hands on the truck ... but I told my son over the phone to override the overdrive, by using the button in the end of the trans shifter stem (like we do sometimes when towing). And, that pausing/straining/slipping is gone.
I still have not had the chance to look for any codes
So, I have a torque converter clutch problem?
Driving, for the time being, with the overdrive shut off ... I am not doing any damage?
Any chance a transmission flush would solve the problem? The fluid is a little old.
Is it the torque converter itself that is failing? Or is it an external component, part of the electronic control system, that is failing and may need to be replaced?
Thanks for any info.
(Suddenly find myself unemployed, and have no money for a major repair)
Old 08-01-2009, 10:09 PM
Mustang6147's Avatar
Mustang6147
Mustang6147 is offline
I am surprised you never noticed that before...
Old 08-01-2009, 10:25 PM
ironmine's Avatar
ironmine
ironmine is offline
It has just started to do this. It is not normal operation.
Thanks
Old 08-02-2009, 06:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,641 Likes on 1,102 Posts
You can drive the entire life of the truck with the OD off and not hurt anything.
Is the fluid low?
Old 08-02-2009, 08:44 PM
aldridgec's Avatar
aldridgec
I think you need to drive the truck personally and confirm this. Selecting 3rd gear (again IIRC) changes the lockup characteristics of the torque converter. I don't think it does the lock unlock thing in 3rd.
Old 08-02-2009, 10:49 PM
ironmine's Avatar
ironmine
ironmine is offline
Yea ... tomorrow I'll have the truck ... actually look at the fluid level and condition, etc ....
The TC clutch locks up in 3rd, too? So, this is the 4r100 shift sequence:
1st; into 2nd; into 3rd; TC locks; TC unlocks/into 4th; TC locks
Thanks
Old 08-02-2009, 11:58 PM
aldridgec's Avatar
aldridgec
Right, but I think it holds in 3rd, it doesn't unlock when you let off the gas.
Old 08-03-2009, 08:02 AM
dkf's Avatar
dkf
dkf is offline
The torque converter unlocks as soon as you let of the gas. They do this to prevent a noise from the slop in the drivetrain which you would get if the TQ stays locked. Its a lot easier to notice the TQ lockup in 3rd and 4th but the TQ will lock up in 2nd if you hold the gear long enough. You just don't notice TQ lockup in 1st and 2nd because it rarely happens. The stock shift and TQ lock strategy on the 4r100 blows and thats putting it lightly. This was all done to make a nice smooth quiet truck which most people want or they will complain.
Might want to take the truck to a qualified local trans shop. Dealers are no good at working on transmissions in my experience.
Old 08-03-2009, 11:37 AM
aldridgec's Avatar
aldridgec
I think the lockup in 2nd varies on year and PCM program revision too.
Old 08-03-2009, 11:42 AM
Johnny Langton
That is correct.
JL
mx21
15
10-11-2014 06:47 PM
tfarvour
2004 - 2008 F150
11-10-2009 07:37 PM
kwberks
1997 - 2003 F150
10-18-2005 08:44 AM
psu1xj
General Automotive Discussion
15
10-28-2004 02:19 PM
Quick Reply: Trans Slips When Remove-Then-Replace Foot On Accelerator ?
