ok, so I dont know whats happening here. every 10-15 minutes my phone becomes disconnected from the sync bluetooth and i have to hit the "phone" button on the steering wheel for it to reconnect.
anyone else having similar problems? how do i fix this?
Mine did it once...Check your bt settings on the phone and make sure it's set to hidden on visibility after pairing it up. I did that, and all is well. I had it set to automatic or something. Once it's paired you don't want it looking for other devices as it will disconnect.
hmm ok so my phone didnt have that option on it. but I did find out that my phone was not set to primary, and since setting it to be the primary phone. Since doing this it has stayed connected, but we'll see if it stays like that.
