ignition actuator??
Old Jul 27, 2009 | 11:49 PM
whatthencuz's Avatar
whatthencuz
ignition actuator??
there is a rod on my steering column that causes my truck to turn off. I start my truck and it turns on right away but as soon as I let go of the switch (ignition cylinder), the truck turns off. When I jiggle the rod it starts working fine.
http://www.2carpros.com/forum/1988-ford-f150--ignition-switch-replacement-vt195218.html
where the vice grips are grabbing. (i know its not a 82 but thats the closest picture i could find online)
Old Jul 28, 2009 | 03:25 AM
Ken Blythen's Avatar
Ken Blythen
The switch & the cylinder both have 5 corresponding positions, but the switch has slotted holes where it mounts to the column for adjustment. The free-play needs to be set midway, before the two nuts holding the switch, are tightened down.
It's also possible the switch or cylinder are dry & sticking - I removed my switch and cleaned it with compressed air & contact cleaner, then greased it up with dielectric grease a couple of months ago - it smoothed up the action a lot. The key cylinder itself is meant to be assembled into the column with some regular grease.
I dropped the steering column down out of the dash to do all this, but if you're only adjusting the free-play on the switch, you might not need to go to that trouble.
Old Jul 28, 2009 | 08:58 PM
Franklin2's Avatar
Franklin2
Sounds like this might the classic broken piece #14 in the diagram above. You have one of these if you have a tilt column. It's made out of pot metal, and the Ford dealer has a bucket load, they break all the time.
Old Jul 31, 2009 | 10:36 PM
whatthencuz
well i took it to the mechanic and it was the switch (the wires) they were loose and old. I got a new switch and now it starts right up and no more problems and my horn works too lol
mad2smile
Jan 19, 2011 12:01 PM
ejj44
1997 - 2003 F150
15
Mar 16, 2010 07:19 PM
rastasj
Feb 5, 2010 11:47 AM
meader1977
Oct 8, 2009 12:57 PM
