Coolant in the cylinder head
My 85 I6 just starting making a gurgling sound about 2 days ago. went out today and started it up and was getting worse. So i started to check things out and with the engine running and oil cap off looking down in the head with a light fresh green coolant is everywhere
the kicker is the engine is not blowing white smoke out the tail pipe, and is running as it always has run before. The intake and exhaust gasket is all chewed up and was hacked in by somebody before me. Does coolant run through the intake manifold. I dont know whether its a cracked head, head gasket, intake gasket. what do you guys think?
safety first!
in your radiator/coolant?
Gurgling sound???
You could take your valve cover off and pressurize the cooling system and take
a look....
EDIT: Drain your oil, see how much coolant is in it.
I wouldn't run the engine in this condition....
Sprucegreen
1997-2006 Expedition & Navigator
06-05-2015 08:28 AM
Hotrodhoarder
108
08-29-2014 05:25 PM
73FOMO
02-02-2014 11:20 PM
