Coolant leaking from oil pan after new head gaskets!
Hey, I have a 1976 F100 wiith a 1978 4bbl 400cu motor, c6 tran, and 9" Rear. I got it on trade knowing it needed a new radiator. The truck would run, but I cranked once for 10 seconds when I traded for it. After putting in a new radiator, thermostat, etc., I cranked it up. It cranked fine and during idle I saw that I needed new head gaskets. All the coolant was leaking from the oil pan and where head meets block right at gaskets. I changed the head gasket (and of course the valley pan intake gaskets, exhaust gaskets for my long tube headers, valve cover gaskets, and so on). After getting it all back together, it is not firing up, and coolant is still coming out from oil pan right above the passenger motor mount. The repair went smooth. It isn't my first head gasket, but I am new to Fords. It is turning over, but gas and air were popping out from top of carb, I figured the dist. was 180 degrees off. I would appreciate any ideas or tricks you guys may have to figure out whats wrong. I hope it isn't a cracked block. The previous owner said he rebuilt the motor not to long before I got it. He just painted the truck with a single-stage blue from summit racing, and wasn't happy with it. That is why he said he wanted to get rid of it. I traded him a running 1989 Toyota Celica GT Liftback 5 speed. I got a good trade, as long as I don't have a crack. Could this coolant leaking be leftover from the broken head gaskets letting water in making it's way out? Water Pump? Timing cover? Any info and anyone really familiar with this 400 motor, I will really appreciate anything. Thank you guys. I am ready to get this torque on the road. She is a sexy truck. I will post some pictures of truck and engine soon. Thanks-Jeremy
oil pan gaskets but haven't installed yet. Was really curious add to why there was still water in there.
I can pinpoint exactly where from. Out of oil pan above passenger side motor mount. I was thinking that could be an issue. Can that cause the coolant to go straight to pan? I will be dropping the pan tomorrow. Do I really need to take off motor mounts on this 400? It looks like I could slide it out.
Well coolant cant leak from a oil pan gasket unless theres several gallons of it in there so your leak must be elsewhere and it sounds to me you like a cracked or warped head. If you can get a radiator ckeck pump tester just pressurize the system and look for the leak, also check so see if there is coolant in the oil pad. Good luck
No, I'm talking about the oil pan. Even while the engine is attempting to start is was leaking from oil pan. There wasn't any run off from somewhere else. I felt and looked everywhere behind, freeze plugs, and it is dripping from the pan. I'm new to Ford, not cars. I appreciate everu ones advice. It was leaking from the same place from pan before I changed head gaskets. It fixed all leaks except from the pan. I'm dropping it anyway to change the gaskets, and hopefully I will find the answer down there. Thanks guys!-Jeremy
Could be a manifold deal also.
Pressure test and you'll find it.
Don't get down, I just built a bitchin new engine that runs great but after a few months I found oil in the coolant.
So I tore a brand new engine out and am tearing it down.
Stuff happens, we just put our head down and roll the stone.
