Need some number decoding
Old Jul 27, 2009 | 06:05 PM
66erv's Avatar
66erv
I have 2 1966 f-250's one is a 2 wheel drive and one a 4X4. I want to put the 2 wheel cab on the 4X4 chassis, is this possible with out major mods.
Here are the warranty numbers for both trucks.
#'s for 4X4
F26BK817702, WB or Color 120, Model F-260, Body D81, Trans A, Axle 25K What is an F-260?
#'s for 2X4
F25YR886225, WB 129, Color 8M, Model F-250, Body 2D81, Trans A, Axle 24
Also could someone tell me were to look for parts needed for rebuilding the 4X4 axles and transfer case.
Any information will be truly appreciated. Thank you.
Old Jul 27, 2009 | 08:04 PM
camperspecial65's Avatar
camperspecial65
In a nutshell...no...different cab mounts, different steering box and steering linkage...different steering column...also the 4WD column goes out the floor of the cab vs the firewall on the 2WD cab. If it were my truck...I would keep the 4wd...cab IS the same as ALL 4WD trucks and F350s EXCEPT 1966 F100 4WD which use the 2WD cab from 65-6.
A F260 is a 3/4 ton(F250) factory 4WD truck
The door tags decodes as follows:
F26: F250 4WD truck from factory
B: 300 6 cylinder engine
K: Kansas City assy. plant
817702: Feb 1966 build date
WB is 120...length in inches, color code would be a letter/s a blank color code means it was special ordered.
Model...explained above
Body D81: D: Med. Beige crush vinyl and med. beige cody pattern woven plastic
81 is a conventional cab truck
A: NP435 4 speed trans.
Axle 25K...25 is rear axle...4.56 Dana 60 open rear end, K is front axle: 4.55 ratio also..if you need parts for this you need to ID the particular axle model as there are a few different variations...metal tag should be bolted to front cover.
The 2WD truck...
F25: F series 3/4 ton 2WD truck
Y: 352 8 cylinder engine
R: San Jose assy. plant
886225: Early July 1966 build date
WB 129: longbed truck, wheelbase in inches
Color 8M ??? M is wimboldon white...theres no numbers in exterior paint codes...B is turquoise.
Model: F250...3/4 ton 2WD truck
Body 2D81: B1 is covered above...2D is interior trim code...there is no 2D...just D as noted above..
Trans: A...NP435 trans.
Axle 24: 4,10 open Dana 60
Again, for the 4WD front axle...post the tag info and help will come your way in finding parts :-)
Theres other differences, but these are the major ones..
- cs65
Old Jul 27, 2009 | 09:43 PM
66erv's Avatar
66erv
Thanks for the info.
The cab on the 4WD drive is beyond repair from Wisconsin. The 2WD drive is from Arizona and in almost perfect condition. I want to take the cab and front clip from the 2WD and put it on the 4WD frame.
I would also like to install power steering. How difficult is that procedure? It doesn't look easy. I also want to replace th I6 with a 390 FE, can that be accomplished without severe head aches?
The front axle ID Tag #s are as follows.
C6TA-AZ
2777-3 4.55 ratio
I am new to this forum and I can not say enough thanks.
Old Jul 28, 2009 | 02:32 AM
camperspecial65
IMO, you would be miles ahead of the game to find another 4WD or F350 cab to use...
Its interchange is 1961-4 All F100/F250 with body type 81(non integral body)
1961-66 F350--F600 (81)
1965 F100-F250 4WD (81)
1966 F250 4WD (81)
1961 F700 before s/n 170,001
You shouldnt have to much trouble finding one of those trucks...theres lots out there still...just gotta look...
I hope this helps, cs65
Old Jul 28, 2009 | 06:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6TA-AZ
2777-3 4.55 ratio
Welcome to FTE
C6TA-AZ: Dana 44F-HD / 4.55-1 / non Limited Slip / 3500 lb. Front Axle Capacity.
Model Code F260 = F250 4WD / 6800 lbs. Gross Vehicle Weight Rating.
There are specific Model Codes for F Series Trucks, it all depends on how they were originally equipped.
The Model Code not only defines 2WD or 4WD, but the GWVR as well.
Other 1966 F250 4WD examples: F261 = 4900 lbs. GVWR / F262 = 7700 lbs. GVWR
Old Jul 28, 2009 | 08:04 PM
66erv's Avatar
66erv
Thanks you for all the help, you guys are great. I will keep the 2WD as is, and probably be selling some Axles and a transfer.
Anybody need parts.
Thanks again!
Old Jul 28, 2009 | 08:21 PM
Bill W's Avatar
Bill W
Post them in the Classified's here on the site, and Welcome to FTE!
Old Jul 28, 2009 | 08:35 PM
camperspecial65
post a pic or 10 in the classifieds or your gallery of the 4WD.....
- cs65
Old Jul 29, 2009 | 10:51 AM
waynes91's Avatar
waynes91
I purchased the following PS assist kit, easy install. I see that your truck is 66, the below may have kit for 65-66.
http://www.classicperform.com/Store/...k/5764PSKA.htm
You can find it here also:
http://vintageford.com/sect_search.c...ering-%20Power
07179-1
RAM POWER STEERING KIT 1957-64
1957-64. RAM style power steering kits attach to your I-beam axle and pitman arm. Utilizes your stock steering box. Includes heavy duty tie rod with ends, hydraulic cylinder assembly, drag link control valve, hardware, and instructions. Use a power steering pump and brackets designed for the late model engine you have installed.
Page 338 2009PT in the catalog.
Grape Nehi
Jul 23, 2016 02:58 AM
Keith B
Apr 18, 2016 12:49 PM
tylers60s
Jul 14, 2015 11:48 PM
Rusty_Old_F250
Nov 29, 2013 02:09 PM
RawIron81
Feb 16, 2012 10:14 PM
