66 Ranger Package
Old Jul 26, 2009 | 12:19 PM
Stuffengineer's Avatar
Stuffengineer
66 Ranger Package
I have one of these but someone changed it to a bench seat. Is there a source for the seat parts and console? Was this a common package or how rare is it?
Old Jul 26, 2009 | 01:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Look on your trucks Warranty Plate which is located on the left door face below the latch for the BODY code and post it here.
The BODY code is the only way to know...for certain...whether the truck was originally a Ranger...or not.
Someone could have swapped front fender Ranger emblems, or changed fenders, getting them from a Ranger.
All Rangers came with bucket seats, a center console, sweep speedometer instrument cluster, a vinyl cover that hid the fuel tank and carpeting.
The seats and vinyl upholstery are the same as 1965 or 1966 Mustangs.
The seat tracks are the same as 1965/70 Mustangs.
The console is the same as 1964/65 Falcon Sprints.
Old Jul 26, 2009 | 04:03 PM
Stuffengineer
Here is a pic of the data
http://www.flickr.com/photos/stuffengineer/
Old Jul 26, 2009 | 05:07 PM
masterqi's Avatar
masterqi
V81 = Ranger
I haven't seen many (any?) with that.
Seems crazy that someone changed it to a bench seat after all!
Old Jul 26, 2009 | 05:28 PM
camperspecial65's Avatar
camperspecial65
Its a Ranger...V is Used on 1966 F100/250(81B) - bucket seats.The description of the material is Red crinkle vinyl and red rosette pattern vinyl.
The rest of the tag decodes as follows:
F10: F100 series 2WD truck, 1/2 ton rating
A: 240 6 cylinder engine
R: San Jose, Ca. assembly plant
732,072: August 1965 build date...early August approxamately as the Aug. run begins with 732,001
129: wheelbase in inches...long bed truck
JM: exterior color: J = Rangoon Red and W is Wimboldon white.
V81...covered above..
G: transmission code...automatic 3 speed.
A8: rear axle ratio...3.54 locking Dana 44
Max GVW: 5000...trucks max capacity with cargo and people in pounds.
Cert. Net HP RPM: 129HP @ 4000RPM...engines HP rating at specified RPM
DSO: 89= Transportation Service...Im clueless about what this means...this is whats stated in the Ford Parts catalog...
Bill(NumberDummy) will chime in on that one Im pretty sure.
Regarding the seats...they were taken out probably by someone with a Mustang in need or want of them as they are identical...
- cs65
Last edited by camperspecial65; Jul 26, 2009 at 05:29 PM. Reason: added seat info...
Old Jul 26, 2009 | 05:38 PM
Bill W's Avatar
Bill W
there is a Guy on the site that reproduce's the ranger seat brackets, i have his info around here somewhere.... if you want it send me a e-mail or pm, or ask in the fourm, i will dig it up for you.
Old Jul 26, 2009 | 08:39 PM
Stuffengineer
Thanks guy's. Thats what makes these forums great. One thing I noted though, the serial # is 732012 so I guess that makes it #12 off the line for 66. What I found was that DSO 89 transportation services is a vehicle that was built for use by Ford ie; testing, photos, executive ride.
Truck does not have the vinyl covering the gas tank, but I can see screw holes from the fasteners that held it there. Of course no carpet, no console. Box has the lower tool box compartment, was this a seperate option or part of Ranger package too. Transmission is still a cruisematic. Engine still 240 but was replaced with ford factory long block. Someone put a power brake boster in. Power steering has been added, looks like a 70 - 72 colum as it has the hazard switch on it.
Old Jul 26, 2009 | 08:50 PM
drof46's Avatar
drof46
Better be dedicated if you want to bring it back to original. You could have your bench seat redone 3X for what your about to spend on the buckets.
Old Jul 26, 2009 | 10:35 PM
gritsngumbo's Avatar
gritsngumbo
If I'm not mistaken the console's are being repoped (or at least most of the pieces that make it up are). Check out a Falcon site and yes the 65-66 Mustang seats are hard to come by, especially at a decent price/condition. You can get the coverings and the foam, but even a decent set of Mustang frames are pretty pricey.
Old Jul 26, 2009 | 10:38 PM
camperspecial65
For package composition, look in my gallery as i have the breakdown of all the packages in there from my literature...The bedside toolbox was an option totally unto itself...not part of any package on an F100.
As for the early 66 model...you are right...BUT just from the San Jose assembly line...there were other plants using the same NUMBERS, but the plant code would be different...so for example if theres 8 plants...there is/was a total of 8 trucks with that number...but the plant code would be different...
Either way, its a low production truck for certain...a keep if you as me...and thats the first truck Ive ever decoded with that DSO code...
- cs65
Old Jul 27, 2009 | 02:56 AM
NumberDummy
DSO 89: Transportation Services = Ford Motor Company Executive vehicle used (most likely in this case) by the NorCal (San Jose) Ford District Sales Zone Office.
1966 serial number range: 732,001 thru 914.000 which means that #732012 is one of the first 1966 trucks (includes all series: B/C/E/F/N/NT/P/T/TL/H/W/WT) to roll off the assembly line.
Since it was most likely the first Ranger assembled in San Jose, it was prolly driven by a Ford "Road Man" who visited all the dealers in the district promoting and demonstrating new products.
Parts of the Falcon Sprint console have been reproduced: Console: body, liner, padded vinyl lid (in three colors: Red, Black, Palomino), aluminum tray.
One of the sources who sells these parts is Dearborn Classics (dearbornclassics.com) located in Bend, Oregon. The console parts are shown on page 51 in their catalog.
Old Jul 27, 2009 | 08:30 AM
BarnieTrk's Avatar
BarnieTrk
NOW THAT'S JUST TOO COOL!!!!!
Bill,
Thank goodness for you and your informational knowledge!
Otherwise, guys like Stuffengineer would not realize that this isn't just some truck - but a truck worth restoring!
BarnieTrk
Old Jul 27, 2009 | 03:17 PM
camperspecial65
...restoring and keeping correct...
definately not your typical truck...
- cs65
Old Jul 27, 2009 | 04:04 PM
Stuffengineer
Fortunatly or unfortunatly this truck has its share of rust. My son and I have just started the tear down, it will be a frame off (not our first). Bought this truck a couple years ago off ebay, just getting to it now. I don't think anyone in its past knew what they had.
Truck was first sold into Denver CO. From the US it moved to Northern Ontario Canada, and has changed hands 3 times before I got it.
Will let you know when I can get some pictures posted. Should try to keep a pictoral record on Flickr.
Any guess as to its value completed?
Is there any production numbers on Ranger packages.
I had contacted Ford but they could not tell me anything since it was built before 67. Does anyone know if you could search out information in the archives at the Henry Ford Museum?
Really appreciate everyones help with this. If anyone has a lead on the seat risers or a used console let me know.
I checked with Dearborn classics and they have a console rebuild kit which has the major pieces, but will still need hardware, hinges etc.
Old Jul 27, 2009 | 04:08 PM
NumberDummy
Originally Posted by Bill W
there is a Guy on the site that reproduces the ranger seat riser brackets
What Bill W said....
No individual production figures are available for Rangers, Camper Specials, Custom Cabs, Standard Cab, how many trucks came with 352's or I-6's, how many were short or long beds.
This is it: 224,497 1966 F100 2WD Styleside pickups were assembled.
btw: Ford "officially" can't tell you anything inre to 1967/79 trucks (or cars) either. Why?
Because, in the late 1980's, Ford was gonna toss all these old records in the TRASH!
A Mustang 'nut' in Phoenix AZ found out about this, acquired it all. So when Ford gets an inquiry, they have to get the info from him.
martiauto.com is the source. Individuals can order a build sheet for their vehicles from Marti...and there is a charge for this service.
This is known in the hobby as a Marti Report.
