Advice please!
Old Jul 28, 2009 | 06:33 PM
bryanj's Avatar
bryanj
Originally Posted by PaysonPSD
Rear brakes on an E99 are the same. Front brakes are the same size but the rotors are shallower.
E99 Duallys have less differences then E99 Single Rear wheel models.
Here's the list:
Some differences between Early 99 and 99.5
Credit to Chase (aka superduty4x4), Ron aka (Ron's Power Stroke) and in Bold credit to Jet (aka SolidGround) RIP.
It I did not credit everyone envolved with this I apologize.
Early 99 has a wicked wheel stock from the factory. And much smaller turbo (spools faster, though)
The early99 has 120cc(AB code) injectors the late99-03 has 140cc(AD code) injectors.
The early99 has 2" intake plenums. The late99-03 has 3" intake plenums.
The early99 has a 15* swash plate HPOP. The late99-03 has a 17* swash plate HPOP.
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater relay side by side. Both relays are above the passenger side valve cover toward the front of the truck.
The early99 has a totally different air intake that is not inter changeable with the late99-03 (except for DRW trucks) . But you can put the late99 air cleaner assembly in the early99 truck.
The early99 track rod has smaller mounting bolts than the late99-03. (except for DRW trucks)
The early99 has shallower rotors than the late99-03. (except DRW trucks)
The early99 has shorter hub-bearings than the late99-03. (except DRW trucks)
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are round. (except DRW trucks)
The early99 has a different pitman arm than the late99-03. (except DRW trucks)
The early99 does not have the AIH like the late99-03.
The early99 does not have the automatic transmission fluid cooler in the radiator.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come on when you set the cruise control. Some, but not all early99 trucks have the light in the dash already. A newer PCM(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green light on the right side edge, half way up.
That is excellent info. So it sounds like the brakes and a few other items are not any different for the DRW trucks. The tranny cooler and the turbo are different and I can handle that. As I find out more info, I'll probably be asking more questions.
Bryan
Old Jul 28, 2009 | 06:55 PM
Izzy351's Avatar
Izzy351
Bryan
That's what it's all about! Come on back if you have any more questions!
diesel lover
Feb 28, 2016 09:57 AM
meck1
Escape & Escape Hybrid
Apr 5, 2015 05:57 PM
sgt.bigjim
20
Mar 20, 2014 09:32 PM
Buy_American74
2009 - 2014 F150
30
Dec 8, 2013 12:02 AM
