10.85 volts with engine running?
Old Jul 27, 2009 | 01:33 PM
HH60FE's Avatar
HH60FE
Slow to start this AM, (actually noticed this Sunday comming out of the woods after camping this weekend, did have the music going, but was careful not to run it down). When it started, I checked voltage at both batts and was only 10.85/10.84. SES light was on for a couple minutes. Batts are 9 months and upper alt is 9 months. I will check ALL connections for cleanleness and tightness, but initial thought is the upper alternator. I had this replaced under warrintee 9 months ago at the dealer, but my warrintee is out and so is the alternator warrintee (12,000 miles). Am I on the right track? Oh, its 90 miles back to the house with no batt light, just didn't appear to recharge.
Thanks
Old Jul 27, 2009 | 01:37 PM
superduty4x4's Avatar
superduty4x4
I think you answered your own question
Old Jul 27, 2009 | 02:22 PM
danskool's Avatar
danskool
Go Bills !
You can take off the alternator and stop by an autozone/napa. They will check it for you if the terminal cleaning don't do it.
Old Jul 27, 2009 | 03:47 PM
Izzy351's Avatar
Izzy351
Mine sits around 13.7-14.2V after first starting & the glow plugs are done. That's even with headlights on & AC fan running.
And yes, you're on the right track, but you have that whole dual-alt thing most of us don't have. Might make sure the associated electronics are doing what they're supposed to...
Old Jul 27, 2009 | 03:51 PM
HH60FE's Avatar
HH60FE
Thanks for the response.
Joe, when this happened last year, I could never get a good answer about that second alternator. I've "heard" that its not tied into the charging system but is there for accessories? Doesn't make sense to me, how else would it know when there is a draw for it to start powering up?
Old Jul 27, 2009 | 03:54 PM
stormyrider's Avatar
stormyrider
I would run the alternator to an auto electric shop. They can rebuild the one you have for less then a new rebuildt one and it will probably last longer also. Make sure they know it is on a diesel as the regulator is different in a gasser.
Old Jul 27, 2009 | 08:43 PM
HH60FE's Avatar
HH60FE
UPDATE: Cleaned everything (minor corrosion), made sure everything was tight, charged both batts up to 12v, got truck running and checked voltage from big post on alternator to positive post on batt = zero volts. Is the alternator shot?
Old Jul 27, 2009 | 08:58 PM
pmasley's Avatar
pmasley
From the big post on the alt to the pos post on the bat will read 0. Read voltage from the big post on alt to ground.
megawatt00's Avatar
megawatt00
You need to check form the big post on the alt to ground. You will get 0 volts where you tested because you are testing positive to positive.
Old Jul 27, 2009 | 09:09 PM
HH60FE's Avatar
HH60FE
OK, just checked to ground and it is 11.2 with truck running. Battery voltage is 11.2, soooo?
Old Jul 28, 2009 | 07:25 AM
HH60FE's Avatar
HH60FE
If I'm reading the same volts from the alternator as the battery reads (11.2v), I'm not getting anything from the altornator correct?
Old Jul 28, 2009 | 07:34 AM
farmdad's Avatar
farmdad
You got it. Time to get the alternator replaced. The reading that you are getting from the alternator is coming from the batteries since the alt. isn't putting out any power. I've come to the conclusion that a used OE alternator from a "recycling" yard is better than a rebuilt one from a parts house. Even if you would have to get an OE one rebuilt, it would still be better and maybe cheaper.
Old Jul 28, 2009 | 08:03 AM
PwerStroke99's Avatar
PwerStroke99
Need a new alternator
HH60FE's Avatar
HH60FE
Thanks Mark. That is a decient idea I never thought of.
Old Jul 28, 2009 | 08:05 AM
stormyrider
Actually he would have read the voltage drop across that area. in this case zero volts is good, means no voltage drop and good connections. To test alternator output you need to read from ground to alternator output post and should read around 14vdc if everything is kosher.
