weird
Old Jul 27, 2009 | 12:56 PM
zer0z4's Avatar
zer0z4
weird
so my neighbors 05 f150 cant be read by my scanner. just says error. tried it on my excursion reads it just fine. its an ob2 scanner, what could it be?
Old Jul 27, 2009 | 04:06 PM
FTE Trigger's Avatar
FTE Trigger
If its one of those Actrons or similar breed. There was a note in the instructions to turn the key in the OFF position for 10-20 sec(?). Then retry.
The Actron cp9135 is really stubborn about reading mine, but it will after cycling the key for a few times. Maybe yours is similar.
My snap-on and National Instruments DAQ/Active data logger don't have issues reading any codes or other vehicle telemetry.
I think its just qwerk inherit with the "consumer-friendly" code readers...
Old Jul 27, 2009 | 07:18 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
what year is your Excursion?
and does your code reader support OBD-II Can Bus?
There are 5 different protocols that the OBD-II systems uses. 2 Japanese, 1 European and 2 American. Ford has used the Can Bus since 2004 in the trucks, and 2005 in the cars.
So if your reader doesn't support Can Bus...it just won't work.
Mdavidson1974
Oct 18, 2016 06:24 PM
rdbesq
Computer Chips & Tuners
Oct 26, 2015 12:02 AM
ranlyn54
15
Aug 23, 2015 11:56 PM
Subsailor1127
6.7L Power Stroke Diesel
13
Apr 10, 2015 07:29 AM
wheelzzs
Nov 10, 2009 07:51 AM
