help with ignition actuator
Old Feb 2, 2018 | 08:04 PM
  #31
88n94's Avatar
88n94
Originally Posted by trip2way
@FordGumby, I replaced the lock cylinder and no change.
I wonder how far I'll need to go before I see the root cause...? I'll be sure and post a follow up.
So far I've got the steering wheel pulled and about to drop the column.
As soon as you remove the plastic cowling from around the steering column, 2 screws accessible from the bottom, you should be able to tell the cause of the problem. I'm almost certain you will find a broken actuator. Very common with the '87 to '91 Ford trucks.
Old Feb 8, 2018 | 11:36 AM
  #32
trip2way's Avatar
trip2way
Actuator broken... but not where I expected.
Now, going to pull the pivot pins, roll pins, and replace the actuator.
Wish I had a machine shop nearby that would custom cut me one out of a different material.
Old Feb 18, 2018 | 05:45 PM
  #33
Broncor's Avatar
Broncor
On my list of things to do, when I turn the key the ignition tumbler is very stiff to turn to start and you have to manually turn it back to complete the start.
I pulled this apart back when i learned that the actuator can be the source of problem. Mine is not broken, I cleaned everything I could as well lubricated too.
being that nothing appears broken what could the problem be.
i didn't read every reply in this thread so sorry if I'm rehashing this.
thanks.
Old Feb 18, 2018 | 05:58 PM
  #34
trip2way's Avatar
trip2way
thanks.
it's likley the upper actuator. Doubt it's broken...just needs lubrication.
Old Feb 18, 2018 | 06:05 PM
  #35
Broncor's Avatar
Broncor
Thank you trip2way!
Old Feb 27, 2018 | 06:46 PM
  #36
Geoff Adams's Avatar
Geoff Adams
I find myself in the same boat as Snowcrash47,
"The way mine switch is now, there is no spring in it now so it doesn't go to start and spring back to run. I have to turn the switch all the way until it stops to put it in run mode with the dash lights lighting up and then use a push button to start it. Does this sound like the actuator, the ignition switch or both?"
How do you "set up" the actuating rod and the column switch internal position to correctly operate the ignition? After replacing any broken parts of course.
Thanks
Geoff
Old Feb 27, 2018 | 06:54 PM
  #37
88n94's Avatar
88n94
What year and model truck do you have?
Old Feb 28, 2018 | 12:23 PM
  #38
Geoff Adams
"91 F150 xlt lariat w/tilt, cruise and 5.0 and aod.
I bought the truck, recently (2 wks ago), it needed the key and cylinder replaced. It had the key "horns or wings" or whatever they are called twisted right off but there was still enough to grab a hold of carefully to turn the cylinder. Looking in through the key hole/slot you could see that the inside was not properly lined up. I was able to get the cylinder out even without the key and replaced it with one from auto zone. So now there is a key for the truck. However it needs to be turned all the way to the start position just to get the truck turned on and a push button on the lower right of the dash is used to engage the starter. When rotated back to the lock position (there seems to be a bit of slop i.e. movement with nothing happening) it does lock the wheel and it will turn beyond to the acc position but nothing there works. Accessories that is, don't work in that position.
So I am trying to learn what might be needed to be repaired as I go along here also including the myriad of other problems as well. What can I expect from a $1500 truck that has been so obviously abused that even I don't believe the 93,975 miles on the clock. Turn signal switch, left rear brake light (not the bulb or ground), Hazard lights, power windows, door locks, rear fuel pump and both tank gauges. More too, including mechanical stuff. I'll have lots to do so it's good that I'm retired, I guess.
Geoff
Old Feb 28, 2018 | 01:24 PM
  #39
88n94's Avatar
88n94
If you haven't already removed the cowling from around the steering column, you will need to do so to investigate. 2 screws accessible from the bottom side to remove the cowling. You may have to drop the steering column to remove the cowling. Fairly easy to drop the steering column, 2 or 4 small bolts under the dash area accessible from the bottom.
Once the cowling is removed, it should be fairly easy to see the problem. If you are really lucky, the position of the switch would just need adjusted. If the actuator is broken, not nearly so easy.
Old Mar 30, 2024 | 01:10 AM
  #40
TravisLauter's Avatar
TravisLauter
Trailering
Originally Posted by FordGumby
You might want to check the ignition lock cylinder first. The key would spin freely if that were to break & that is more common. Much easier to fix too, just a few minutes.
Edit: perhaps there would be no resistance if this were true...
Good luck
actually I'm having the same problem and I've got a new ignition lock cylinder and I've got a new ignition switch both installed still had the same problem so it's actually the ignition actuator and if anybody has any diagram on how this looks please let me know
Old Mar 30, 2024 | 07:51 AM
  #41
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE. what year truck?
how to fix it depends on the year.
Old Mar 30, 2024 | 12:47 PM
  #42
TravisLauter
Trailering
1999 f350 7.3l
Old Mar 30, 2024 | 01:04 PM
  #43
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by TravisLauter
1999 f350 7.3l
This is the wrong forum for your truck. This is the 1987-1996 F-Series forum. You should ask in the 1999-2016 Super Duty forum.
Old Mar 30, 2024 | 10:00 PM
  #44
TravisLauter
Trailering
I already have but none have answered thanks anyway.
Robbgt
2009 - 2014 F150
15
Mar 27, 2024 07:58 PM
yrots
Jan 25, 2021 11:36 PM
buzzurd
Jan 19, 2017 02:10 PM
Moose Mendolia
Oct 30, 2016 01:21 PM
BuckHunter1960
May 22, 2016 03:47 PM
