Bets tar remover?
Old Jul 27, 2009 | 11:17 AM
ROUSTYBOY's Avatar
ROUSTYBOY
Bets tar remover?
They just blacktopped our road and I've got tar all over my unit. Getting this stuf off a white F-150 4WD isn't my idea of fun. Any input as to the best remover? I've tried two and neither work well.
Old Jul 27, 2009 | 11:42 AM
SteveVFX4's Avatar
SteveVFX4
did you try kerosene? My detailer uses that. I think some of the bug/tar removers are made from kerosene anyways. Wear gloves too I guess. You'll need to re-wax those areas after using the kerosene.
Here's some other forum post that talks about using kerosene:
http://www.waxforum.com/showthread.p...4129#post14129
Old Jul 27, 2009 | 04:26 PM
silver05fx4's Avatar
silver05fx4
well i would go out and get a a good clay bar or use wd-40 and rewax it after your done
i've used paint thinner before too, when i work in a body shop but i was also repainting the panel too
Old Jul 27, 2009 | 04:51 PM
Beechkid's Avatar
Beechkid
Definitely avoid the clay bar!
Mineral spirits/paint thinner is what all commercial bug/tar remover products are. Afterwards, wash with hot soapy water. If you have any residual stain 9doubtfull but possible, use 3M hand glaze, then wax as you would normally.
Old Jul 27, 2009 | 04:52 PM
Skip1970's Avatar
Skip1970
wire wheel
Old Jul 27, 2009 | 05:37 PM
mebe2k's Avatar
mebe2k
Avon Skin-So-soft.. believe me.. it works..and it won't jack up your paint..
Old Jul 27, 2009 | 07:27 PM
YoGeorge's Avatar
YoGeorge
Mineral spirits...
That is what commercial tar removers are and also what Ziebart rustproofing remover is...you can even use it to get tar, oily stains, or auto rustproofing out of fabrics. Use a lot, soak the tar, and let it sit as long as possible, although it will want to run onto the ground.
Hell, if I'm washing a car or truck and have a small spot of tar, I'll grab the charcoal lighter out of the garage and use that--it's a similar solvent.
Lighter fluid will probably also work--this is even safe for vintage guitars and wood when you need to get wax or gunk off.
None of these will hurt car paint. What will hurt car paint is rubbing any abrasives into it, so wash the mud off the tar first, and if the tar is full of sand or gravel, don't be rubbing that into your paint.
George
Old Jul 27, 2009 | 09:22 PM
tcarro2001's Avatar
tcarro2001
WD-40........ It works everytime, and will get almost anything off of your paint.
Old Jul 28, 2009 | 08:46 AM
Buck 1's Avatar
Buck 1
WD-40 is safe to use, and, if you let it soak for a few minutes, the pressure from the garden hose will wash the tar off. Soap up the area after hosing off, then wax it. Also works to remove decals and the stickers the dealers put on the vehicle.
Cherokee Hunter
Oct 25, 2014 08:24 AM
turbogus
31
Mar 18, 2014 10:11 AM
78 Ranger
Paint & Bodywork
Aug 25, 2012 07:41 PM
1BFT
Appearance & Dress-Up
May 10, 2004 01:35 AM
skeleton
Paint & Bodywork
Sep 25, 2001 12:28 PM
